BRAKE RETURN PIPE PART NUMBER
Re: BRAKE RETURN PIPE PART NUMBER
Post by citronut »
Tim Leech wrote:Thanks Malcolm, do I need to see the car for the RP number? (its 160 miles away)
cant you contact whoever is were the car is and ask them to get the rp No.
or maybe a member on here living in the area of the car
Tom, yooohooo!
Lol
Looking at the engine bay number pic there's a number above the paint code, 3805, will it be this?
Post by citronut »
yep that should be the rp No.
so going by that ut will be this pipe
95 595 681
Post by RxBX »
citronut wrote:here is two options for front to rear brake feed pipe dependent on rp No.,
this is for a non power steering car, and the only others listed are for ABS cars
i know you said return pipe,
95 595 681
HYDRAULIC TUBE
LONG 3035
- UNTIL RPO 04346
96 117 585
DIAM 3,5-3100
- SINCE RPO 04347
and here is a metal pipe showing under brake circuit which one end terminates at the dosour valve,
and the other end is from 4 way union at the rear sub frame for the rear suspension
96 117 584
HYDRAULIC TUBE
DIAM 3,5-3375
non of which are showing as NFP
Tim Leech wrote:Looking at the engine bay number pic there's a number above the paint code, 3805, will it be this?
citronut wrote:yep that should be the rp No.
so going by that it will be this pipe
95 595 681
That was a handy tip of mine then Tim, to zoom into that Photo shot :wink:
So that's make its Length 3035mm as you know I have a good S/H (If you can't get a new one) which approx. 3160mm in length which would fit !
You'd just need to loose a bit when fitting it up (Or I could shorten it and re-flare the end for you) if its the one which has a union fitting on both ends as one of the pipes which go to the front near the bulk-head/floor pan area just connects into a rubber pipe and therefore does not have a union fitting in that position, so if it was you could just shorten the end accordingly to suit !
From memory it will have a union on each end, although you've worried now as all the pipes did!
Maybe this one will be slightly different as it's so early - it does have some features generally seen on Mk1's rather than Mk2's.
95 595 681
Right thanks Malcolm contact my local stealer tomorrow.
Post by citronut »
citsncycles wrote:From memory it will have a union on each end, although you've worried now as all the pipes did!
there is one pipe out of the front to rear 4 pipes that just pligs into a rubber hose above the front sub frame, it also dose have a flair in it to help it stay in the rubber hose,
but this particular pipe has a flair nut at both ends as its the main brake feed to the rear,
looking at that under bonnet shot there'z bin rodents under there Tim
Plenty of mice! Thankfully nothing's been chewed and eveything works.
Yay ordered today, £15 inc VAT! will be here next week.
OK - we hlould be able to book another day to go down at the X rally - I'm off the following week from Wednesday onwards.
