Could this be causing my running problems???
x 82
Now i'm no oldie, and this aint no diesel engine where talking (the knowledge i have of this petrol stuff is veeeerryryy limited), but i thought the caps where meant to have 4 contacts, one for each HT lead which goes to a plug in each of the 4 cylinders and sets fire to stuff?
So i guess it would try to run on two cylinders occasionally arcing to the other two and getting really confusing?
Is there a way to get round these caps? Seem to think i've seen a BX with some gizmo from a 405 that got rid of the dizzy, some big black box thing?
I know that with the 16v its simply not ecconomical to do anything but buy the uber expensive £50 jobbie, are the 8v's as prone to failure?
Ian_Fearn
Post by Ian_Fearn »
The cap has been replaced, it made no difference to the running problems i already had.
The later Motronic 8v cars had a coil pack instead of a distributor cap.
Over and out from me
