So far; option a) is to remove subframe completely giving me full access to pipework. This has been suggested as the right way to go. b) replace the one offending pipe without touching the rest, meaning perhaps that the subframe doesn't have to come off. Apparently this is also doable, though I am again told that if I get it wrong and the new pipe touches anything it will soon fail from chafing, and the idea of dropping the frame is to make sure all pipes are properly clipped in and separated from each other.
So what d'yer think? To get the rear up I have a length of scaffold pole which I can run through the large holes in the rear towing mount plates, and with axle stands under them to give me height enough to work. But what about the front?? It will be depressurised and I have to get underneath to undo the pipe unions to fit the new pipe. I can either put jacks under the front ( which sounds a bit scary - I really want two wheels firmly on the ground) or I could perhaps run the nose a wee bit up some standard size ramps so that even when it's down I will still have room to crawl under. What do you guys do??
Also, looking at the thread below there is reference to dropping the frame on one side only which is enough to give you access.
It's been said before that you should replace all four pipes cos if one goes the others won't be far behind. Good practice I suppose but extra work? And if the others are all OK and still have the black coating then should this be an issue?
We just stripped out the scrappy subframe for practice and on one pipe there's what looks like bolt-on bridging piece fitted. Is this a quick fix for a busted pipe? Never seen one before. Are they any use?
And while I'm in there I shall do both rear arm bearings, new rear tyres, etc...
