Bungs
Bungs
Hi, does anybody have a pair of those black rubbery bung things that go into the big hole at the bottom corner of each of the front wings? Both mine seem perished.
ed4ferrets
Post by ed4ferrets »
Assuming they're situated round about where you might hang mudflaps, I seem to have a couple of good'uns.
Pm me your address and i'll bung them in the post :lol:
'94 XM 2.1TD Break
'63 Renault Caravelle
I'll do a photo and post it up to save confusion... Thanks for the offer. Just need to make sure we're talking about the same things :D
ed4ferrets
For sure, you may have noticed from previous posts I'm regularly confused :roll: !!
'94 XM 2.1TD Break
Me too. Are you going to the French Car Show?
ed4ferrets
Yep, just have to get to Jon's place and then experience his tweaked TD to the show, looking forward to it!!
'94 XM 2.1TD Break
Here's what I'm talking about. In the door frame, under the hinges, a big hole filled with a rubber bung on the wing/A pillar. I need a couple of these if anybody's got a pair. Beer tokens available.
ed4ferrets
They aren't the one's I was on about but are identical anyway, advise addy will 'bung' in the post tomorrow!
'94 XM 2.1TD Break
Post by jeremy »
They may be a standard blind grommet - in which case you will probably get them from a specialist rubber supplier - try yellow pages.
Bungs arrived. Cheers! Have replaced split/crumbling old ones, and now? - now I guess, the section won't fill up with crud and water... Ho evidence that it ever did - but you can't be too careful.
Again, many thanks
