Breaking TD Estate
- Jaba
- x 83
Breaking TD Estate
This car was in pretty good nick apart from the fatal rear subframe body rust.
Most parts are available including water temperature sensor and good spheres.
I can bring stuff to the CCC National meet on the Saturday
Re: Breaking TD Estate
so what colour is/was the car and was it a TZD,
if it were and was red what condition is the front bumper and is it two tone (grey over red ) with the wide trim,
allso what condition is the rubber strip each side of the hand brake like,
and were are you located
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Drivers side sun visor please? Assuming it still stays up of its own accord?
Hi Jaba,
i would like the ducting/sound deadening under the bonnet thats especially for a turbo, not the standard n/a stuff. However, cant do the CCC meet. Could it be removed and rolled up to be posted?
hi there. im after rear lights, rear arms if abs equipped and centre bits of dashboard in black if possible, also hows the radiator? looking for a white bonnet too. yhe list goes on... where are you based?
- Jaba
- x 83
Yo - its a GREEN one. All the exterior trims are pretty good as is the bumper.citronut wrote:so what colour is/was the car and was it a TZD,
also what condition is the rubber strip each side of the hand brake like,
Location = OX11 Newbury/Oxford
I think the H/brake trim is shredded on one side the way they all seem to be.
It says on the V5 BX17 TZD turbo diesel 1993
- Jaba
- x 83
Its yours Bandido. It does stay up too.BX Bandit wrote:Drivers side sun visor please? Assuming it still stays up of its own accord?
- Jaba
- x 83
I will see if it can easily be posted, or I do come to Henfield from time to time so could deliver if you are near there.Mothman wrote:Hi Jaba,
- Jaba
- x 83
Dollywobbler did say he wanted the rear lights but I am not sure if he still does. If not then they are yours.really? wrote:hi there. im after rear lights, rear arms if abs equipped and centre bits of dashboard in black if possible, also hows the radiator? looking for a white bonnet too. yhe list goes on... where are you based?
The rear arms are ABS and both have newish wheel and arm bearings, but I need a pair of arms of some sort on car to keep it mobile.
I am near Didcot so it would be best if you came and helped yourself.
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Moochos Grassyass signor!Jaba wrote:Its yours Bandido. It does stay up too.BX Bandit wrote:Drivers side sun visor please? Assuming it still stays up of its own accord?
Not going too ccc, are you going to Stratford?
If not, will you consider posting? Please let me know how much I owe you.
- barry badger
I'd like the boot carpet if it's in good condition.
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
Did the TZD estates get the black interior ? If so, whats the centre console like ?
- Jaba
- x 83
Its not very good but I have a good spare one somewhere. I will look it out. Can you pick it up at the National??barry badger wrote:I'd like the boot carpet if it's in good condition.
- Jaba
- x 83
Yep, its black. not sure exactly what you call the centre console but the bits you see are pretty good. It has a flashing led fitted that is linked to the central locking.TizzyD wrote:Did the TZD estates get the black interior ? If so, whats the centre console like ?
Centre console is the bit that goes round the handbrake and the height adjuster
