Estate tow bar
Thread Bear
Estate tow bar
Post by Thread Bear »
I am in the market for an Estate tow bar if anyone has one spare. I am in Oxfordshire.
Re: Estate tow bar
I have a genuine Citroen one, with the proper plug in wiring kit. PM on its way.
Re: Estate tow bar
Post by Tinkley »
The genuine towbars are actually pretty good. Mines on its 3rd BX and the wiring plug in makes it a doddle. Though the boot trim near side never settles down quite right afterwards on the hatch version.
The easy way to fit is get a lump of 3X2 just long enough to wedge the jaw apart when you want to line up the mount bolts on the main under chassis rails. Pigs unless you use this 'assistance'.
Thread Bear
Re: Estate tow bar
Never had to do one yet as always fitted. Odd that you like to find a car without, as it suggests the arse has not been pulled of it, but then of course put one on.
The old BX Estate had a proper one on and I confess to towing a 1964 Merc fintail saloon on a trailer made from the left overs of the Forth Bridge. From Reading/Winneresh end to Faringdon. It did it quite happily. Very naughty boy. Towing probably did for that car, the engine gave up slowly.
The others had an after market one with four bolts which was fine for box trailers/A framed small cars/racing car trailer without wheels. But the fixing looks minimal, I agree. I have one for the Saloon TZD, Walter, but might uprate to a genuine type later when I can afford to do old Walt up. I think the Auto can remain virgin.
Re: Estate tow bar
Post by Tinkley »
I've only got the towbar for towing a racing dinghy so all up weight can't be more than 200Kg max including trailer. Only a car full of people so hardly wrecking it. Existing towbar doesn't bother me as long as its only been pulling relatively light things. Never tried towing a Merc fintail....
Get away with not towing the safety boats at my local Sailing club as the BX tow limit is so low, ha ha
x 82
Re: Estate tow bar
I have one on my estate which I am breaking.
You can have it for free if you come over to Didcot to take it off the car. There may be other bits you want as well.
