1.7td gearbox
monkeyfeet
1.7td gearbox
Post by monkeyfeet »
Taken from body damaged running write-off a couple of years back. been lying around the back of my old shed since. Not brilliantly well stored but never drained of it's oil. Part of my clear-out so has got to go. It's the tip otherwise :(
Thanks
Brian
Re: 1.7td gearbox
Post by Brian »
Sending PM.
Visa 17D 1986 192K Sorn
BX 17TZD 1992 192K
306 XRDT 1996 175K
monkeyfeet
Re: 1.7td gearbox
Sorry all. It's not for a 1.7td it belongs to a 1.9d. So 1.9 lump and gearbox for sale. Offers in region of 2 bottles of beer (it's got to go and seems a shame to take it to the scrappy)
Re: 1.7td gearbox
If you'd split then I'd be interested in the gearbox. I could collect the weekend of 20th July. Has it been stored under cover?
monkeyfeet
Re: 1.7td gearbox
If you mean would I let them go separately, yes of course, no problem (They're already separated physically). As to the storage side, well most of the time wrapped up, but as I found out this morning the shaft is stuck - I'll put something on to grip it and turn lightly to see what happens. And yes if you can't make it until July I'll keep it for you :)
Re: 1.7td gearbox
What age car did these come from please?
monkeyfeet
Re: 1.7td gearbox
I think that the donor car was either an E or F reg, so '87 or '88.
Re: 1.7td gearbox
Sounds like it's likely to be a BE1 box then, but the engine could be either version at that age - does it have the large flat air box on top of the engine, or the inlet manifold with 1 large intake?
monkeyfeet
Re: 1.7td gearbox
I think it could be a BE1 box, but as for the motor I don't think that I have the inlet system (I'll look though) - do you know of any other features that would help me to identify it please?
Re: 1.7td gearbox
If either manifold is missing then just look at the shape of the ports in the head where they fit - sqare ports are early, rounded ones are late. If it's the early type engine I'd be interested in it as a spare for Timex, and maybe the box if Mat changes his mind.
monkeyfeet
Re: 1.7td gearbox
Well I hope that this is worth a thousand words:
Not a brilliant shot I know, but does it help at all? :)
Re: 1.7td gearbox
citsncycles wrote:maybe the box if Mat changes his mind.
You're welcome to it Mike - I was waiting to hear if it had seized but I've just noticed it's a TD 'box which for some reason I had missed :oops: That's the later oval port head though so unlikely to be a BE1 'box.
Pogo
Re: 1.7td gearbox
Post by Pogo »
Think he thought it was a 1.7td box, but now thinks it a 1.9d box
1990 Black BX GTI
Re: 1.7td gearbox
Ah yes, I've just re-read the rest of the thread. I'll let Mike have first dibs on it though as realistically I'm running short of time to swap the gearbox on the white one, plus this may be no better.
monkeyfeet
Re: 1.7td gearbox
Yes sorry about the confusion earlier, it's now been confirmed as a 1.9d box (thanks Brian!) not a 1.7td.
Makes sense as I've got the rest of the 1.9 engine but mixed it up with another gearbox.
