It's a ZX, but the engine's the same as a BX19D in essence, so I wondered; the oil level warning light flashes indicating low oil, but the oil level's fine. An oil change didn't make it go away either.
In true Citroen-fault-fixing-style, which wire do I have to wiggle to make it behave, lol? Where's the sensor (must be some sort of float? If so is it stuck - so where do I tap it -
Phil
