Anyone got any?
The ones on the red TZD are cracked and i dont like them in such a state.
Thanks in advance.
Wanted: Estate rear light units
- Stinkwheel
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Re: Wanted: Estate rear light units
You just missed some that finished on E-BAY only on MondayStinkwheel wrote:Anyone got any?
Thanks in advance.
But if I spot any I'll PM you
Edit:- Also check with 'Jaba' to see if he's got the set which Ian wanted for the Estate (Which is now yours) !
The /\ quote from THIS thread for ref.Jaba wrote:Dollywobbler did say he wanted the rear lights but I am not sure if he still does. If not then they are yours.really? wrote:hi there. im after rear lights, rear arms if abs equipped and centre bits of dashboard in black if possible, also hows the radiator? looking for a white bonnet too. yhe list goes on... where are you based?
The rear arms are ABS and both have newish wheel and arm bearings, but I need a pair of arms of some sort on car to keep it mobile.
I am near Didcot so it would be best if you came and helped yourself.
Good luck !
- Stinkwheel
Thanks Rx, I shall PM jaba momentarily.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Jaba
- x 83
PM received and responded too positively momentarily.
