Still a bit bumpy!
Still a bit bumpy!
The ride on my TZI still isnt as good as I would like, the front crashes over bumps and potholes but floates otherwise where as the GT just wafts.
New struts (pleides recon) were fitted 2 months, the spheres were replaced in 2010 (with non sporty ones) when I got it (its done 3500 miles since) but its nowhere near as soft as the GT.
Someone said the height correctors maybe bunged up and to try some hydraflush?
I have changed the LHM also.
Any thoughs...I wasnt my magic carpet ride which the GT and DTR both had, they both had the later type set up.
Re: Still a bit bumpy!
What's the ride height like. Geoff Rothon suggested to me that mine was riding a bit low and that a quick check was to fit 4 fingers vertically between the top of the wheel and wheel arch when at normal height. I adjusted mine which did make a difference. Also, are you certain the spheres are correct? Any part numbers?
Wishbone bushes? They can look good, but might be worn or hard.
- x 94
You don't know the shelf-life or exact spec of the spheres. I used to see them wrongly box all the time, which could produce a multitude of errors!
I'd change them for new anyway. If it makes no difference, just bung the new ones on the shelf in the garage and wait until another BX needs them. There isn't much else that can affect the ride stiffness other than spheres and struts. Everything else will only make it noisy/unrefined/handle badly.
Otherwise ride height as suggested. Could be too high.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Surely the earlier (i.e. taper needle roller bearing) setup would be smoother and would explain a better ride on the GT - but you say you've had it changed to the later bush type?
I guess all small maladies can add up.
Sphere type/age?
Same age LHM?
New struts tighter than 'worn in' ones?
Tyre type/make/age/size/pressure?
Sphere type/age?
Same age LHM?
Timex does something similar occasionally (bushes in the frot incidentally). I tend to find that it's because the suspension has settled a bit low, and shifting to intermediate and back usually does the trick, so I'm guessing height correcter sticky or crudded up.
Thread Bear
Not qualified to comment but I can report that I was amazed at the amount of crude that was in my height correctors. To the extent I am not sure flushing would have cleared it all. You would know better than I. Most was dusty stuff but there were some granules and one 'shaving'. This car did have a known period of neglect and the poor strut seals suggests excess wear into the LHM. Scheduled for struts, other clean up and a flush as I am certain there is muck still in there. A look at the filter in the reserve will prove my fears when the time comes. At the moment I am limping the car along on about half a lt of LHM in three weeks - though I had one other leak on a feed back. A failed roadside repair. I occasional sense a lose in suppleness and I put that down to either some crap moving or when the seal is weaping as the strut is in a bad position. For this car that is on low. I think that would make sense on a little used car not really maintained and the n/s that gets the Nottingham pot holes and drains of its previous life. Bit of surface rust knocked out a seal or just a pour surface finish on a worn seal?
Cheers guys, some good suggestions, could I fit comfort spheres? (im not bothered about flying round corners but it rolls alot anyway). I am happy to throw some new spheres at it.
I think the next thing is to try some hydraflush and see if it helps, it wasnt very well maintained when I got it so maybe bunge up.
The car was only MOT'ed last month and the bushes were worn I would have been told (as he would have failed it).
Front ride height seems right to me. but I will try the 4 fingers
The struts have made a difference to the ride, they dont stick like before and the car is alot smoother and all the groaning has gone, but it still doesnt absorbs the bumps as well as it should.
Stinkwheel
As a quick aside, where do you even get hydraflush from these days?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
I'll have a look in the pound shop
But seriously, where have you tried?
Yes, which is what I'll be doing shortly. If you look at the table towards this end of this thread you can see that the TZI had fairly firm spheres, same as the non ABS GTi. So even if your spheres are correct for the model and in good condition they may be firmer that you would prefer. I was surprised how much difference it made temporarily swapping the spheres from the TGD to mine!Tim wrote:could I fit comfort spheres?
I am sure when I replaced them I fitted standard 1.6/1.9 BX saloon spheres (for comfort). But if it makes a difference I will get some softer ones (matt if you can tell me where you get yours etc).
I'm getting mine from AEP (also in the link
) but unless they decided to keep some in as a stock item it'll be 12-15 weeks until the next order is shipped to them. If I find mine too soft then I could sell them to you, but I'll certainly let you know how they feel. Pliades may sell them too, but I didn't have time to enquire.
Not forgetting our foreign friends have had good results using diesel in place of hyroflush.
Really? even so I think Ill stick to hydrflush, dont fancy driving it round with 4 litres of diesel in the pipes.
