You know the one, that sits between the actuating arm and the actual clutch fork.
Suitable for a 1993 19n/a diesel.
It appears the new purchase has lost this somehow with its failure and slack in everything.
Pretty urgent please, anyone got one they could bung in the post?
Wanted: Clutch Fork 'pin'
- Stinkwheel
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Re: Wanted: Clutch Fork 'pin'
Hi, Easy to make one up from a suitable bolt.
Adjust the nut/bolt about half way of it's travel.
Pull the arm apart.
Measure the distance between the arm and the cupped bolt.
Select a bolt or rod of suitable diameter and length.
Cut off the bolt head.
Form convexed shape to both ends.
Grease both ends.
Adjust As required.
Bingo....
Hint:
Used this method a few times now, when the adjustment is all used up.
Making a longer rod, extends the life of the clutch many many miles..
Pull the arm apart.
Grease both ends.
Adjust As required.
Bingo....
Hint:
Visa 17D 1986 192K Sorn
BX 17TZD 1992 192K
306 XRDT 1996 175K
BX 17TZD 1992 192K
306 XRDT 1996 175K
- Stinkwheel
Thanks Brian,Brian wrote:Hi, Easy to make one up from a suitable bolt.
Pull the arm apart.
Grease both ends.
Adjust As required.
Bingo....
Hint:
Makes perfect sense this actually, im surprised i didnt think of doing similar, i like a nice cheap fix
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Just measured the one I have, 43mm from end of part spherical to ditto ie total length before rounding.
Should give you something to work with. Oh and Ø8mm so any old M8 bolt (8.8 grade) with smooth section would do nicely
- Stinkwheel
Tinkley wrote:Just measured the one I have, 43mm from end of part spherical to ditto ie total length before rounding.
Excellent, thanks, now i dont even have to go out in the rain to measure, i can just knock one up !!
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
