Wanted.. Mk2 16v dash, speedo, rev counter etc
- My Cars: 1989 PH2 16v. White
Seat Leon FR. Whiter
I am after a 16v dash binnacle, mine has a standard Gti dash at present with the lower redline, it was changed by the previous owner as the rev counter packed up on the original, it needs to be a fully working dash obviously, has anyone got one knocking around ?
Vince.
Vince.
- x 148
Re: Wanted.. Mk2 16v dash, speedo, rev counter etc
Theres one on eBay.
Thank Tim I missed that is it a Mk2 instrument panel ? I will take a punt on that one if no one has a known fully functional one on here.
- x 148
Kitch is breaking two so maybe he can help? the only one I have is a for a diesel.
Hi, I have one.
Its off a phase 2 16V.
It weighs quite a bit.
Regards Phil
Regards Phil
the things you learn off this forum! can someone post the 2 pics up so i can see the difference. i didnt think there was one! cheers.
Pm sentCaulkhead wrote:Hi, I have one.
Regards Phil
- x 88
Weighs quite a bit? Are you talking about the same thing here?Caulkhead wrote:Hi, I have one.
Regards Phil
Hi Kitch,
I'll weigh it tomorrow. Your right, it is not as heavy as I remember but I have to post it.
I'm guessing at 1.5 kg but I have some accurate scales.
PhilS
PhilS
Bumped !
I am still in the market if anyone has one , it's only the instrument panel I need not the complete plastic surround with the hazard/rear demist etc.
- x 148
Dont sent it via royal fail, try http://www.interparcel.com" onclick="window.open(this.href);return false;
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I have a peugeot one if you are interested Vince. Gauges, speedo and rpm complete.
Thanks for the offer, Are the clocks the same in the Peugeot then, what would be involved in swapping them over ?
