Wanted - plastic handle for manually opening sun roof
kbami8txd
Seem to've lost mine !
16valver
Re: Wanted - plastic handle for manually opening sun roof
do you still need one? i'll get a picture of mine and you can see if its the same.
Thought they were an allen key?
Certainly were on the electric ones, but not sure whether any models had a manual sunroof. If not then it's likely to be an aftermarket job, or a dealer fit option.
If it's a TXD it will have a factory electric roof.
16valver
That's the Sun-Blind (Plastic Bit) , Not part of the Sun-Roof handle part16valver wrote:..............
the only plastic bit i could find near the sunroof?
