timing marks
timing marks
now the strobe light has arrived gonna check the timing on the gti, i have found the tdc mark on the flywheel but cannot find any relevent marks on the crankcase? i have checked the haynes and nothing there either apart from a 16 with a timing plate attached to the crankcase. anyone got a pic?
- JayW
- x 13
Re: timing marks
The flywheel is timed by putting a dowel through the hole in the block behind th starter motor which will locate (and lock into) into the back of the flywheel.
Re: timing marks
this is for ignition timing, not valve timing, will i need a timing plate that sits in the top hole? jetronic system so no tdc sensors.
- JayW
- x 13
Re: timing marks
Sorry, misunderstood OP.
Can't be of any help i'm afraid!
Re: timing marks
sounds like you timing graduant ( if thats a real word, tiz now ) plate is missing,
Re: timing marks
does anyone have one to fit?
