water ingress, was it ever concluded
Post by citronut »
firstly were is the thread regarding water entering the rear half of the car, boot area and rear seat and foot wells,
my TZD has been SORN for the last 6 months, now booked in for a MOT on Monday,
i went to start her up yesterday only to see mushrooms/fun guy's growing in the O/S rear foot well :evil: :roll: #-o ,
she must have a bog under the carpet in that corner :roll: :(
Re: water ingress, was it ever concluded
Couple of things to check for this:
Check the rear door seals, the rear door window seals, the door drain holes and the waterproof membrane behind the door panel are all in good condition.
Check the tailgate seal is doing it's job - sounds unlikely but I've known a leaking boot or tailgate seal let water in that makes it's way forward through the car.
Finally, is it only the rear footwells that are damp - water can easily make its way from the front of the car backwards, especially if it tends to drop the back end when parked.
Finally, finally, if you et a chance, pull all the carpet out the back to let it dry out, I know from Timex how water ingress can rot the floorpan!
Edited once to remove sunroof checks after realising it's an estate #-o :roll:
Timex was good at filling its rear footwells when I owned it. I eventually traced this to a torn FRONT door seal.
Still does it, partly from badly fitting back doors, partly from a hole under the screen surround on the passenger side and partly from a hole above the screen surround on the drivers side - guess what the first job is once Fred's on the road!
Post by citronut »
thanks for the replies
it might be the rear quarter window bonding, as im sure i have seen water running down the inside of defiantly the N/S one,
the other thought i had was maybe the roof rail/s
I think Mat has had experience of a split roof joint under one of the plastic capping pieces. If the rear quarter light in the door is leaking it may be worth checking the metal at the bottom of the glass - I have 2 doors to repair in this area.
I certainly think that's where water was getting in, as it stopped once I sealed between trim and roof panel. That was quite obvious though, as the headlining was wet so in the case of a mystery leak it may be elsewhere. Door seals can leak not only between seal and door, but water can track around the U section where it pushes onto the lip, and appear at the botom.
Post by citronut »
citsncycles wrote: If the rear quarter light in the door is leaking it may be worth checking the metal at the bottom of the glass - I have 2 doors to repair in this area.
i dont mean the quarter light in the rear door Mike as these are not bonded, i mean the glass above the rear wing,
mat_fenwick wrote: That was quite obvious though, as the headlining was wet
ok thanks Mat
so if the head lining is dry that should rule that one out,
mat_fenwick wrote: Door seals can leak not only between seal and door, but water can track around the U section where it pushes onto the lip, and appear at the botom.
the usual leak via doors is if the door card membrane is missing or damaged it will cause water to enter between the bottom of the card and the door its self, which in turn runs in and over the bottom section of the door seal
Ah sorry, not had any experience of those windows, although I've seen other cars with evidence of adhesive/sealant failure.
demag
Post by demag »
Probably not this but on the Xm a lot of mystery leaks were traced back to the roof aerial mounting.
Dave.
1990 Bx TGS automatic.
