4x4 has failed its MOT (NOW MOT'D)
Ian_Fearn
Post by Ian_Fearn »
Thanks to Tim Leech for the MOT.
Unfortunately its failed on:
the headlights aiming too low
carbon monoxide emissions 4% (max is 3.5%)
CV boot split
Over and out from me
Fix-able? (Emissions, I mean!)
Stewart (oily!)
Post by Stewart (oily!) »
Give you a tenner for it guv and take it :wink: off yer hands, not a bad list apart from the emissions? I could send you some biodiesel for it , that reduces the emissions seriously :)
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
sleepy0905
Post by sleepy0905 »
Ian if it has been stood it probably needs a bloody good thrashing down a dual carridgeway thats what cured my TZS after it failed at 3.9 the thrash brought it down to 3.4 but i also had to change the oil and filter.
Ian_Fearn
Post by Ian_Fearn »
I've just got the gunsons gas tester on it and brought it down nearly a % by reducing the idle from about 1100rpm to 800rpm.
It had a right thrashing to Tims place. Hopefully it should be ok next time. The alternative is for me to stand there with a screwdriver when they test it so i can adjust it when its there.
tim leech
Post by tim leech »
ErmI dont think thats practical! lol Will pass its retest on Monday no probs.
Ian_Fearn
Post by Ian_Fearn »
I really hope it passes this time round!!
Its been treated to fresh oil, plugs and a CV boot today.
tim leech
Post by tim leech »
Should be fine then! Did u sort the bulbs?
Ian_Fearn
Post by Ian_Fearn »
The bulbs were just advisories. But yes, i've sorted them anyway.
tim leech
Post by tim leech »
Good man.
x 117
Ian, if you have a flow meter type injection fitted then if you turn the mixture adjusting screw OUT three turns this will take the CO down to 2.0 ish at tickover.
You can then screw it in again after the MOT if it runs a bit hesitantly. This assumes you have no serious ignition/injection problems on the car that are giving you the high reading.
x 103
Stewart (oily!) wrote:I could send you some biodiesel for it , that reduces the emissions seriously :)
Stewart
hmmm biodiesel in a 1.9petrol, well i guess then it probably would be worth £10 :D
that is nothing that list! Mine is usually a dead o/s reg plate light (it dies on the drive there every year, and is already dead (blew the bulb on the way to the fcs) and the MOT is due next week), and it normally fails on emmisions first time round (i blame the rad blowing all the coolant out on the last MOT for that though )
Ian_Fearn
Post by Ian_Fearn »
Its now MOT'd, thanks to Mr Tim Leech who got me the MOT done at his dealership and also for getting the dentman round to fix all my dents, it looks great with totally straight lines now!
Some wonderful pics for the up-and-coming calendar, then!
Keeper of the site Goat
Post by cavmad »
Ian, sorry to sound coarse but how much did this dent dude charge? Or if it`s top secret any idea what their usual price is for a couple of small dents?
I have a Corsa diesel here which`ll be on eBay as soon as the new engine is fitted but it has some dents around it which otherwise spoil it`s pretty good condition.
Vauxhall apologist.
