Wanted :Rear height adjuster
richg
Post by richg »
Can anyone help or suggest where to find a rear height adjuster. Assume they are the same for all models ?
Regards
Richard
Re: Wanted :Rear height adjuster
Post by citronut »
view the thread below and scroll to the third post down
http://www.bxclub.co.uk/forum/viewtopic ... +corrector
why do you require one????
richg
Post by richg »
Hi Malcolm
Mine is leaking. So you think it could be made serviceable with a seal kit?
Richard
Post by citronut »
richg wrote:Hi Malcolm
Richard
99% sure the seal kit will sort the leakes, as long as its not the short rubber pipe split/perished
