Various BX Bits for sale (and a ZX HBOL)
My Cars: 1985 Citroen BX19 GT
2013 Nissan Leaf Acenta 24Kw
x 198
Post by saintjamesy89 »
Hi guys, a rather long time no see/speak. Blame that on work and moving house! I have some BX bits to re-home so see below, postage is fine and can be quoted if you give me you're address etc on agreement of purchasing.
TZ style wheel trims, not too bad condition, fitting rings included, but to make them perfect give them a lick of paint. If you use plastic primer it's remarkably easy to paint them. £10
(dark spots on the trims are bubbles from where I washed them - not patches where paint flaked off, scuffed edges, pictures slightly flattering)
TG style wheel trims, quite shonky! Would need a paint unless you're going for the shonky/rat look, then they'd be perfect. These fit by clipping onto the wheel bolts. £5
Pair of rear seat headrests, proper ones with the shorter bars, very good condition, black. £15
14" Steel wheel, round (no buckles) and in good condition. £10
Citroen ZX Haynes manual petrol only, good condition, not too oily/greasy. £5
XU Sump drain plugs with copper and rubber washer, bought several for my TXD Turbo and only ever used a couple. May fit petrol XU's as well? Would need to check or be advised. £1.50 each, 4 available.
BX14 TU (not early suitcase type 1.4) bolt on performance pack! Including Solex 32/34 carb and inlet manifold, relevant oval shaped air intake pipework (standard BX14 are all round fitments, whereas this carb has an oval top face), oval topped air filter housing, relevant (non original BX) 14 coil pack, HT leads to match and distributor also to match. These bits have come off of AX GT's which are rated at 86bhp with this carb. Will post, but these bits are heavy so may be slightly more. £60
(if enough interest I may sell separately, but I spent quite some time/effort/money putting this kit together and it all needs to go)
BX14 TU Alternator, GWO when bought a couple of years ago, has been carefully stored in a dry box, pulley spins freely. £10
GTI style instrument panel for SPARES or use as is, temperature dial robbed and some of the fixing lugs snapped but otherwise working. Will chuck if not sold, so make me an offer if you want it.
1989 BX Petrol handbook in good, albeit slightly dirty condition complete with all booklets. From my old G reg TGE. £5
Two different colour rear light clusters, one looks to be a red tinge, the other blue/green. Both very good condition, rubber seals intact. £8 each.
If you want something, but disagree with my prices, please let me know so we can come to an agreement, however I have priced everything quite reasonably IMO, it all needs to go!
Thanks,
Tom.
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Re: Various BX Bits for sale (and a ZX HBOL)
Good to hear from you Tom, whats to become of that GT!
x 198
Cheers Tim, I'm just writing an update in my GT blog so have a gander in that direction in a few minutes if you like :(
SOLD - 4 sump plugs/washers and both rear headrests (Andy is quick on them buttons!)
SOLD - TZ style trims and rear light clusters.
demag
Post by demag »
Can I have a sump plug please? I'm in Norway and won't be home for a couple of weeks if that's OK.
Dave.
1990 Bx TGS automatic.
x 198
Hi Dave, very sorry but Andy (mothman) has already bagsied all 4 of those (as in my previous post).
demag
Post by demag »
Thanks Tom. Bad connection here. Did notice that but couldn't get back online.
Dave.
x 198
someone suspiciously like me wrote:SOLD - 4 sump plugs/washers and both rear headrests (Andy is quick on them buttons!)
Bumpity bump. I'll have to ebay stuff if it doesn't sell...
