Red TXD on ebay.
Red TXD on ebay.
Reluctant BXpert
Re: Red TXD on ebay.
Post by Caffiend »
ebay seller wrote:The citroen has unfortunatly just failed its MOT on corrosion, areas that need welding are rear corner of cills, two small holes in the boot floor, and two areas of front inner wing, only a few hours work to get it sorted.
(my bold)
Riiiiighhhht ... :lol: Added to the register anyway as seen in the wild.
(Also, SILLS, dammit.)
Vantman
Post by Vantman »
Nothing wrong with 'cills' it's a variant spelling.
2003 Saab 9-3.
x 138
Rotten as a pear then.
Vantman wrote:(Also, SILLS, dammit.)
Seconded
"Tradesmen/lecturers use the spelling cill which seems to tie in with the references here (window cill, cill of lock gate) to the use of cill as a technical term among professionals like builders, architects or engineers and the sill form among the general population.
This also explains the wide difference in frequency; there are fewer professionals than the general population. Hence the mere frequency of a word is not supportive of any arguments about correctness; however, the argument about wanting to APPEAR correct should be modified to match the audience for which one is writing; professional or general."
Thread Bear
Post by Thread Bear »
rutter123 wrote:Rotten as a pear then.
If Cill, can this be rotten as a Pier? Once repaired it can be as burnt as a Pier. Piers are handy after all.
Interesting as I think a Canal lock has a Cill not a Sill. Ox Dicky time.
Reluctant BXpert
Post by Caffiend »
I stand corrected - thought cill was a building not automotive term. Am I allowed to point and laugh at "hydrolic" though? ;P
Post by Tinkley »
Well spotted, so rear subframe mounts to be rebuilt, half the boot and then the front wheel arches (inner wing to arch), under washer bottles, etc etc only a few hours work. Have to say the seller seems to be a whiz with the welder...... :lol:
Can't work out why he/she doesn't fix it up!. I note it is in Brighton, the car obviously loves the sea air.......
Actually mine has very good sills (cills) except the rear blanking plate part which being part of the arch and of course bedded in thet lovely creamy sealant they had gone a bit crusty. Still sorted now along with sub frame mounts. Boot floor, not bad but 100mm sq hole in boot side (n/s), oops but not MOT failure. It will live to fight another day and a bit more welding!. A few little glass/epoxy repairs in these non structural parts is perfectly legal and OK, at least it won't rust there afterwards... :wink:
Post by RxBX »
Bidding for K723 KGF now ended, sold for £255 !
