So Pleiades are out of stock of 3.5mm pipes and are unlikely to restock for a number of weeks. Am on the hunt now for the metal hydraulic pipe from the front offside brake flexi that runs along the cross member to the junction splitter thing. I would have preferred to have one made up from Pleiades as these seem easier to fit.. anyone have any places i could be ringing tomorrow morning? or a part number to refine my search?
thanks again everyone
sourcing pipes!
sourcing pipes!
all i want for christmas is a dukla prague away kit
The fleet:
1992 Citroen BX 19TXD
1972 VW Camper
1969 Triumph Spitfire MKIII
1984 Kawasaki Z750
2002 Ibiza Seat
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
Re: sourcing pipes!
just found this.. anyone used these guys? .. i figure a smidge over 1 meter might be just the job http://www.eurocarcare.net/brake-hoses/ ... -made.html
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
Re: sourcing pipes!
Also worth a try, is Bonapart a 2CV specialist SE of Paris. I had the same problem with 3.5mm pipe and it MUST be Cunifer or the original steel type (pref the black coated stuff) to be safe. You can order with a debit card OK, just e-mail the guy Herve, he's very helpful and has enough English to speak on the phone too. You'll need a bending tool and flange creator too btw. Yes I know it is more a lot more meters but if you do the front/to rear pipes you'll need 15+ meters anyway.
Just make sure the 'nut' part is on the pipe before you create the flange....
Re: sourcing pipes!
here is dimensions, price and part No.'s for this pipe from citroen
non power steering ( so iwould think these are as non ABS )
these two are showing as still available from citroen
95 595 681
HYDRAULIC TUBE
LONG 3035
UNTIL RPO 04346
96 117 585
DIAM 3,5-3100
- SINCE RPO 04347
95595681 HYDRAULIC TUBE 15.53 GBP 18.64 GBP 18.64 GBP
96117585 HYDRAULIC TUBE 17.20 GBP 20.64 GBP 20.64 GBP
with ABS
this one is NFP =no longrer available from citroen
96 042 339
NFP
HYDRAULIC TUBE
DIAM 4,5-1600
96042339 HYDRAULIC TUBE 9.00 GBP 10.80 GBP 10.80 GBP
regasrds malcolm
95 595 681
HYDRAULIC TUBE
LONG 3035
UNTIL RPO 04346
96 117 585
DIAM 3,5-3100
- SINCE RPO 04347
with ABS
96 042 339
NFP
HYDRAULIC TUBE
DIAM 4,5-1600
regasrds malcolm
Re: sourcing pipes!
thanks Malcolm
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
Re: sourcing pipes!
well... its been a tough month of BX spannering.. many thanks to you guys on here i finally have an MOT ! cheers
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
The fleet:
1972 VW Camper
1984 Kawasaki Z750
2002 Ibiza Seat
