Strut Issue
Dominic
Strut Issue
Post by Dominic »
I have a catastophic leak of LHM which is pouring down the inside of the off-side strut gaitor - took 3 litres of LHM to get the 40 miles back from work last night - any insight most welcome!
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Anything that turns money into noise...
Thread Bear
Re: Strut Issue
Post by Thread Bear »
Well not as chronic, but I have a front strut that is passing a lot of LHM. It only does so at a certain height. So I think one of the inner seals is finding a damaged area of strut and leaking at that point. So I am battling my way to the spares car in the briers to get at my spare strut out of it. I dosged changing the last one, but apparently they are pretty simple to change.
Maybe in your case an inner seal has completely failed.
Re: Strut Issue
Sounds like the outer rod seal has failed, recon strut or seal kit needed.
Re: Strut Issue
Whereabouts are you Dominic? If you're nr to Barry @ Bourne Citroen he can repair struts with this problem, if distance is an issue, i'm sure he'd be happy if you posted it etc...
Dominic
Re: Strut Issue
Post by Dominic »
Many thanks - I'm not close to Bourne, but I am close to Malcolm, to whom I am truly indebted! Just for the record the longest part of this job was finding someone to sell me a 36mm socket, which I eventually did, only to find that I couldn't undo the nut, as the strut insides were just turning with the nut - fortunately Malc had one with a top, meaning that the whole plot can just drop out through the wheel arch - job done! May be an idea to mail the old one off to Bourne so I've got a spare!
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
