Wanted o/s/f brake caliper in gwo non abs
As above in good working cond for a 1990 t/d, the piston on mine has too much corrosion and is showing signs of ultimate failure.
Toddman
Re: Wanted o/s/f brake caliper in gwo non abs
They are not sided and pretty sure they are the same on ABS and non ABS versions. Sadly I can't help out though.
- x 116
I have one that is usable. You would need to swap over the yoke as it has been removed.
I seem to recall that the abs versions have a different thread size on the flexi hose.Toddman wrote:They are not sided and pretty sure they are the same on ABS and non ABS versions. Sadly I can't help out though.
- x 116
Yes but its the hose only which has a larger thread size at the other end to accommodate the 4.5mm metal supply pipe.Way2go wrote:I seem to recall that the abs versions have a different thread size on the flexi hose.Toddman wrote:They are not sided and pretty sure they are the same on ABS and non ABS versions. Sadly I can't help out though.
KevR
- x 4
Err, are you sure...? All of mine are very definitely different from right to left - handbrake cable entry, lever and bleed nipple location are different....Toddman wrote:They are not sided
KevR wrote:Err, are you sure...? All of mine are very definitely different from right to left - handbrake cable entry, lever and bleed nipple location are different....Toddman wrote:They are not sided
