Does anyone have the part number for a 1.6 petrol thermostat housing (polymer) with 2 pipe feed and bleed screw. There seem to be lots of different ones that are not the same as the one I have. My unit is the 1.6 XU52C (BA1) type. For the time being I can borrow the (housing) unit on the old engine but as this is the same vintage you 'know' what is going to happen.....
Is this still available from Citroen, maybe?
Turns out there must be at least 2 types - I have both! however they require different top rad hoses. Ideally I'd like to get a 'straight' and down one ie 90 deg to block, rather than the 20/30 deg offset to C/L of vehicle one. I've temporarily forced the 'straight' type hose onto the angled type but it is far from ideal.
