To add to the lively debate on air in the system, here's another oddity (to me).
The power steering on my tzd offers what could best be described as 'inconsistent assistance', which is a bit disconcerting if you have to haul the car into a corner and half way through the assistance cuts in (or vice versa).
I bled the 12mm accumulator screw to the accompaniment of much whooshing followed by a click, and all is well again - full-time steering assistance. This used to be done every 4 weeks or so (2000 miles), now it needs doing every couple of days, so something is deteriorating. There are no leaks in the system, but something ain't right. Help, guidance and insight most welcome.
FDV Failure?
Dominic
FDV Failure?
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Anything that turns money into noise...
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Re: FDV Failure?
Leaking accumulator sphere?
"Stiff power steering
Check the level of the LHM, clean the filters in the reservoir and renew the fluid if necessary. If the filters were very dirty, you should flush the system. If this does not help, you can suspect some failure in the hydraulics like a flat accumulator sphere, faulty pressure regulator, or even a faulty hydraulic pump.
The system is designed to maintain safety: if the pressure drops, the steering goes first, then the suspension so that you still have brakes until the last drops of LHM. And as the steering requires copious amounts of pressure, even a slight pressure drop might make the steering stiff or default to mechanical instead of power steering. This signals an ongoing deterioration of one of the components involved, so if the stiffness cannot be eliminated by simple cleaning, you'll have to replace some parts sooner or later anyhow."
Re: FDV Failure?
This isn't right, once the air is bled it really shouldn't need doing again until the system is drained/refilled. If normal operation is regained after bleeding then this suggests you DO HAVE a leak in the system where it is drawing in air prior to the pump input. You may not see a fluid leak as the input lines are not under pressure but you need to check the quality of the rubber and hose joints for their integrity. If the input lines are all good then really that just leaves the pump itself possibly drawing air in though its shaft bearing/seals?Dominic wrote: I bled the 12mm accumulator screw to the accompaniment of much whooshing followed by a click, and all is well again - full-time steering assistance. This used to be done every 4 weeks or so (2000 miles), now it needs doing every couple of days, so something is deteriorating. There are no leaks in the system, but something ain't right. Help, guidance and insight most welcome.
- x 8
Re: FDV Failure?
More like a 'flat' Accumulator sphere. Normally you might get leaks at some of the Y joints, or T joints, and other parts of the return system as well. These are early warning signs that the Accumulator sphere is past best. Not sure what happens if the bladder becomes porous inside it but guess that would give a lot of nitrogen back into system. Maybe Defender's leaking sphere?
When was it last changed?
PS the 'debate' does concern my 'new' aquisition whereas my current runner and previous 2 (one written off by third party) were 'known' items which were sorted OK. Last 3 cars have identical engines though, even similar carbs, though the auto has a bit of odd stuff added.
Dominic
Re: FDV Failure?
Many thanks y'all. Accumulator sphere last done a year or so ago, but I do starship miles, so worth replacing I guess. I also have a reserve pump. Is it safe to use jubilee clips on the pump?
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Re: FDV Failure?
It is not necessary to replace the accumulator sphere unless the 'tick' time interval has diminished to an unacceptable level.
