C5 Tales from the Electronic Side
Re: C5 Tales from the Electronic Side
If you go for a MAF, be wary of the cheap ones. Sometimes you get lucky, but on ours the cheapo one lasted a year. Found a VDO one for about £60 and it drove so much better with that on!
Got a genuine one, made no difference! Better without the brake binding mind!
Have you checked the thermostat? mine wasn't working very well & the engine wasn't at the correct temperature which meant powah was down a bit along with fuel economy.
replaced it ages back. It was fubar when I got the car, it now gets lovely and warm, but still lunches fuel. It's a heavy car with a sluch box, I'll live with it
Richb
Post by Richb »
I know about thise codes. I have pug planet / lexia. Saves a fortune at the dealer!
2001 Peugeot 206 2.0 Hdi
1999 Peugeot Expert Van
1993 Citroen BX 1.9TXD
1992 Citroen BX 1.9TXD
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
Failed its Mot on front numberplate, replacement sorted for £12.50 & now passed. One advisory on a corroded rear brake pipe. Mileage approx 137k, i'll double check.
bxzx16v
Post by bxzx16v »
Not bad for the MoT Mulley , hows the valver going ?
Mark
Slowly getting there with the valver, borrowed it for the day to attend the x rally, i love driving it :)
rear brake pipes are a mare on these! I know this :(
MY front number plate is knackered too.. must be a C5 thing!
Car needs a service & the coolant temp warning light is coming on more regularly than normal. Coolant level looks fine, so hopefully just a duff sensor, hoping to drop the car off at Barry's this weekend & pick up the valver in time for the Wetherby meet, if not i'll be attending in the C5 spaceship again.
A trip to Barry's a while ago now, has meant an oil change sorted, banging sound at the back was a rear arm bearing, thats been sorted & no more clonking or banging :) Coolant sensor replaced, however the rubbish design meant that the plastic housing its in broke, so a 2nd hand replacement was fitted, no more coolant warning lights on.
