Glow plugs or Battery
kiwi
Post by kiwi »
Have reached a dilemma with the Diesel Turbo Estate I now have.
The battery is clearly fubar being over 7 years old and does not hold a charge overnight with the cold winter weather about to come its going to have to go, I realise that part.
Now the question is really about glow plugs! I never dealt with these before and they do look simple enough to replace. After getting the leaky boost valve sorted out the mechanic mentioned a couple may need replacing. I am thinking replace the lot as I dont have testing gear but am I also correct in thinking that the battery may be contributing a lot to this?
When I jump the car from another vehicle (typically the other Diesel) it starts first time or maybe second if I dont let enough charge hit the battery.
This cars turning out to be a nightmare! Just as I get one leak sorted another appears. Theres a small Oli leak around the area of the clutch housing which I am holding out hope its a Sump gasket or another easy fix but also the Diesel Fuel Tank decided to spring a leak at that awkward location on the top of the tank where the tank vent pipe comes out (nearside for us non euro types.
One step at a time the glow plug v battery which one first?
1990 BX19 TZS Auto 06/11/1989
Re: Glow plugs or Battery
Post by ken newbold »
Battery for sure.
The glow plugs are so easy to test, you can do it with them in situ, but if you wanna be sure, take them out one at a time and connect them to a 12v battery supply, there should be a spark when you connect then they will get hot and glow red, take care! if they don't glow they're knacked.
If it starts from a jump, I'll be surprised if any are gone. Normally if one is down, they're a pig to get started.
x 138
Glow plugs are relatively cheap at less than £20 for a set of 4 and easy to change, my t/d had cold starting issues a few years back, i replaced the battery and glows and all issues were sorted and still good to this day, up until then i was using damp start to get it going some mornings. My theory was at 200k's they were prob knackered and due a change anyway.
Your leak around the gearbox housing could well be the crankshaft oil seal or driveshaft seals or poss from the hyd pump running down the back of the gearbox, had all these to do as well .
kiwi
Post by kiwi »
I switched the battery to the one from my other diesel and it started first time. It was a bit rough so a later investigation on glow plugs will be done.
I can exclude the hyd pump as part of the suspension issue from that I can say it is certainly diesel oil. If its the crankshaft seal how much of a job is that?
Crankshaft seal, not good, gearbox out and new clutch for peace of mind
kiwi
Post by kiwi »
Just the gearbox out? How easy is it to replace the seal though?
x 138
You should be able to pick the old seal out once the flywheel is off.
kiwi
Post by kiwi »
Thats good to know so basically my mechs who will be doing this job have already had practice on gearbox removal from the TXD should be able to do this quicker than last time....yea right...A least I have an idea of labour cost.
Are these seals reasonably priced or some stupid price?
Peanuts
x 138
Sure mine cost less than £10 UK money, its a pretty standard size so you should be able to obtain one easy enough. Whilst the box is out i would be inclined to stick a new clutch in as well, false economy not to unless its reasonably new, check for oil contamination on the clutch plate friction linings.
KevR
Post by KevR »
You can check the glow plugs in situ - disconnect the wires, then run a test lamp between battery positive and the terminal on the glow plug. if it lights up, the plug's probably ok (but may not be 100% good). If it doesn't light up, you know for sure it's a dud. Usually when one goes you hardly notice in normal weather - it's only when it gets cold or the battery's a bit weak that it's an issue.
As far as I remember, the one at the cambelt end is an absolute sod to get at on cars with the Bosch injector pump. No problem on Lucas-CAV versions.
