MOT tester man said I had to fit some covers for the next mot.
So I had a pair of ' mangled ' Xantia ones which I panel bashed into shape .
Not a true fit , although the fixing holes are spot on. With a little excursion of the tinsnips and pliers for the topside of the arm it all fitted very well.
rear brake backplates
Land Rover Discovery TD5
Re: rear brake backplates
Why would it need the covers for the mot ? On c3 Picasso they used to have covers on the rear discs and after a while they were no longer fitted so can't really see why it should have them for the mot as it doesn't effect the operation of the brakes .
1992 BX GTi Hurricane x2
1991 BX Meteor 1.9d
1993 BX TXD Turbo, Ice blue
1987 Visa GTi
1991 BX Meteor 1.9d
1987 Visa GTi
I have a pair of BX rear backplates here rust free and in very good shape £35 pair +£3 postage you will be hard pushed to find a better set. If you want them let me know.
They should only be an MOT failure if they are in a dangerous state and likely to fall off. If you remove the back plates all together it cannot fail the mot for not having them so the MOT man should not have "said I had to fit some covers for the next mot"
- themildbunch
I've had one missing on the rear of my 16v at the last MOT as I hadn't finished trying to remove the snapped bolt fixing the old plate in... didn't fail or get an advisory...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Cliff. I will have them. Let me know when you have the rest of the goodies together.
2001 Peugeot 206 2.0 Hdi
1999 Peugeot Expert Van
1993 Citroen BX 1.9TXD
1992 Citroen BX 1.9TXD
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
Ok Rich sold, got a very busy weekend so will try to get your bits off and all together early next week, will pack them up and send to save you the journey.
