1991 Citroën bx 1.9 tdg breaking
x 137
Re: 1991 Citroën bx 1.9 tdg breaking
loftus hall i have a good flow valve here if you need one, off the car good working order £25 + £3 postage can send asap.
loftus.hall
Post by loftus.hall »
Sounds good, just sent a private message.
loftus.hall
Not sure if pm got to you,
What's best way to pay you? Pay Pal?
x 137
all received.
Dragon Man
Fiat Panda 4x4 Sisley 1991
x 6
Post by Dragon Man »
... does it have a good cam shaft? :twisted:
- JohnDragonMan
Richard811
My Cars: VW T4 Caravelle 2.5tdi (Current)
Citroen bx 1.9 d (For sale)
Citroen bx 16rs Break (Sold)
Post by Richard811 »
Hi Michael
Curious if you can help.
Where my estate parcel shelf pivots as the trail gate opens the near side or passenger side hinge has sheared off.
Any chance you can help here?
Thanks
Dragon Man
x 6
^^ the plastics on mine have snapped on the drivers side causing the parcel shelf to drop :(
- JohnDragonMan
greendale65
x 20
Post by greendale65 »
Hello, Would you have the front seat belts with the stalks
in good clean condition for mot pass.
Thanks
Alan
greendale65
x 20
Hello, Do u have the front seat belts set including
the 2 stalks that are clean for my mot.
Thanks
8) 8)
FireBladeSteve
My Cars: Citroen BX 16 TGS
Saab 900 S
Porsche 911 Carrera 2
BX 16 TRS in 1996 (F343 HDS)
Post by FireBladeSteve »
Hi, I need both screen wash reservoirs for my TGS. Do you happen to know if they're the same size and connections? My car is a H Reg thanks
x 137
Firebladesteve i have a good pair of front/rear screenwash reservoirs with good pumps and caps if you need them, they are nice and clean with no muck inside £23 pair inc post. All mk2's are the same.
FireBladeSteve
Saab 900 S
Thanks for that. As long as they're not cracked and leaking like my current ones then that's fine!
I've PM'd you...
x 137
They are fine no cracks no leaks all good, no pm received.
FireBladeSteve
Saab 900 S
Didn't realise I had to press submit, review it, then press submit again! Anyway, done now..
Pluto
My Cars: 1992 BX19TGD ESTATE 178k
2014 Fiat Ducato Sportivo
Post by Pluto »
If parts are still available from this car I need the passenger side front window seal. The one that pushes into the door and goes all the way around the window.
If you have this please let me know.
Thanks
