Some thing dint sound right so thought I better have a look, think I just caught it!
Espaping Cambelt!
Re: Espaping Cambelt!
Looks as tho your bottom pulley has sheared the keyway i would suspect the end of the crankshaft spline is knackered too.
Lucky the shaft survived but the woodruff key gone and the bottom pulley wobbles well, just need a new woodruff and should be back on the road.
I have a bottom pulley and key if you need one-from a diesel.
- x 4
Lucky escape!
very lucky, well caught. Has it had the crank deal done and not had the pulley tightened properly perhaps?
