WANTED - 4x4 est rear susp cylinder
Jamie_Davies
- My Cars: BX 4x4, BX 14 TGE
I'm looking for a rear suspension cylinder (left hand / UK nearside) for a BX 4x4 estate. These are the kind with the remote sphere, not the type on 2x4 cars that have spheres on their ends. Can anyone help?
assembled
- My Cars: 1991 Citroen BX TZD TURBO 4WD*
*aspirational - x 2
Re: WANTED - 4x4 est rear susp cylinder
Hi, have you looked into modifying standard cylinder?
As far as I remember, it is the same except for a plug instead of a sphere. Can't remember if pipe goes to the 4x4-specific plug or in to an enlarged pipe hole (~10 mm tube instead of 4mm). I think it is connected to the plug... If so, you could simply use a regular cylinder, seal the pipe hole and refit your end plug.
1991 TZD Turbo berline
Ex 1992 TZD Turbo berline, aircon, ABS
Ex 1989 GTi 4x4 berline, ABS
Jamie_Davies
Thanks very much for that advice: I'll get the old one off and take a look (I do have spare cylinders for the 2x4 so if you are right this could be an easy fix. Wish me luck!).
Thanks again,
Jamie
Thanks again,
Jamie
