Wanted, Steel wheel bolt(s)
bowei001
Post by bowei001 »
Does anyone have a spare steel wheel bolt for a BX Mk1? These bolts have a slightly domed head unlike the flat heads on the later bolts. Modern Citroen/Peugeot bolts seem to have a slightly dished head and not enough shoulder to hold the wheel trims tightly.
Thanks, Ian
x 97
Re: Wanted, Steel wheel bolt(s)
No but I got loads of MK2 bolts which I thought were the same?.
bowei001
Post by bowei001 »
The Mk2 bolts that I got from a breaker had flat heads. There must have been a change point sometime but it probably wasn't recorded in a part number change. My 1986 Mk1 has the domed heads. I must admit to being a bit OCD!
