ABS sensor alternatives.
frog
x 12
Post by frog »
Hi all,
Can anyone confirm or deny that 405 and series one Xantia's have the same ABS sensor as the BX? I understand the connectors are different.
I have already re-wired my sensors once before and that has only lasted a couple of years.
Thanks,
1989 Citroën BX 16v
1993 Citroën BX 16v project
senmathal
My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
Re: ABS sensor alternatives.
Post by senmathal »
I have a Xantia ABS sensor on my BX 16 Valve an it works properly.
/Mats
x 116
That is interesting. I have heard that the early 405 sensors work as well with the correct connector.
So all is not lost yet as long as we can source Xantia or 405 sensors. I wonder if both front and rears are compatible though.
