1988 BX coming to USA
Kaapelimies
x 16
Re: 1988 BX coming to USA
Post by Kaapelimies »
Well this is what service.citroen.com knows about your car:
service.citroen.com wrote: Vehicle characteristics
Vehicle family BX
AS/RP N° 04639 CJ 1 0215
Warranty Start Date 01/01/1990
OPB B00C
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY BX
SILHOUETTE 5 DOOR SALOON
ENGINE INJECTION XU5JA
TRANSMISSION BVM5 4X2
STEERING POWER STEERING
Fuel supply-Engine
Gearbox Transmission
Suspension-Steering-Brakes
Body fittings
GLASS (APPEARANCE) TINTED
Interior fittings
FRONT WINDOW LIFT FRT ELECT CONTR FRT WIND LIFTR
REAR WINDOW LIFT ELECT CNTRL RR WINDOW LIFTR
Electrical
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
So, not very much..
antonioconceicao
My Cars: 88 Citroen BX GTI
Post by antonioconceicao »
No sure why but every car I get the antifreeze looks like mud after coming out of the boat
YEsterday flush all the system well before burp the system looked liked this , much better
BTW I always have best resolt with palmolive dish detergent :D
Antonio
1990 Porsche C2 race car G Class
1990 Mercedes G 3.0 Diesel 5 speed
1968 Citroen ID20
1988 Renault 4 TL
1970 Citroen Mehari Beach Car
2007 Porsche Turbo
1988 Citroen CX Turbo
Gone and missed 1988 Renault 5 GT Turbo
antonioconceicao
Hello everyone
The BX keeps adding miles, after cleaning up the colling system it runs much lower temperature and I finally got the colling looking green!
For now I park it until I have more time for it but its a great little car, no problems cruzing at 100 mph and still average 28 mpg since got to USA
some pictures of my family collection
As you can see we like Citroen :D
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
Found 2 of this in our old shop , both are full
I could not found the old gauges to use it but I order a set
Car has AC option , the previous owner told me supposed to be working. When I select cold and the AC buttom the front fans come on, not sure if the compressor is on but it also could be because is not charge or too low
I understand the chances to be working after 30 years are low , but what would be the steps to test it out just for fun :D
I see one port on the bottom front but I cant find the other one , is that possible only has one port ??
Antonio
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
Kaapelimies
x 16
You want to change the thermostat also, normal running temperature for BX is 83-88 celsius depending on the version (and assuming the gauge shows right).
x 82
antonioconceicao wrote: Tue Apr 17, 2018 4:00 pm Found 2 of this in our old shop , both are full
Yes the BX only has one charging port. It is on the high pressure side
antonioconceicao
Thanks to confirm that
Is the High pressure around 250 PSI?
Once again thanks for the help
Antonio
Jaba wrote: Wed Apr 18, 2018 6:02 pm
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
Some updates on the AC
Compressor is working but I notice 3 ports , same size
2 with white caps and one with a black cap on it , all nipples are same size
I check the records on the car was charged back in 2003 , amazing how car got all the invoices since new from Citroen
Does anyone know what are the 2 white cap ports on the compressor ??
Antonio
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
Some updates
I still using the BX, car drives very well, I did some cleaning
The attachment 32105408_10214647824888006_5967121140915634176_n.jpg is no longer available
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
Also replaced all the dashboard lights , all working now
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
On the AC , its under vacum still, but I am waiting for a new dryer , got one from ebay in UK.
I am still learning how AC works, I was thinking to flush the system, except for the compressor, dryer, expansion valve then replace the oil on the compressor and see what happens, will be nice to have a citroen with AC , heat is brutal here
Antonio
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
How to find out if the BX got leaks :P
Mine got none ; )
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
x 82
Hey, nice video. Looks wet over there.
Something not right with the oil level/pressure gauge. The backlight should go out after a minute or so when it changes over from reading the oil level to the oil pressure.
Does yours change over ? What should happen is with ignition on and before starting the engine the gauge should swing over and show the oil level in the sump. Then after starting a short while later it switches to reading the pressure and the white backlight goes out.
Its not a big deal that gauge as I have found that the oil level indicator is not a reliable indicator of how much oil there is and the pressure gauge often gives a very unsteady reading so don't worry too much about yours !
antonioconceicao
Thanks for the info
I didnt know, aways been like this , I check the oil and its fine. Light aways on it doesnt change over :shock:
Always marks the same, maybe one day I will look over until then I will just check the oil level
Thanks again for the info
Antonio
Jaba wrote: Wed May 16, 2018 11:21 pm Hey, nice video. Looks wet over there.
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
antonioconceicao
This past weekend due to the rain most of the drovers bail out on the citroens
Once a year we all meet at Carlisle PA around 100 miles from DC , we normally about 20+ citroen , a lot of everything , really nice day , we do a driving and also a dinner , fun to hang out a see couple citroens
I took the BX this year , car drives amazing. Going up I follow a DS and a CX, due to rain we cruze around 80kph but coming back by myself the BX stay easily 120-140 kph
All day did over 300 miles with the BX .
Antonio
1968 Citroen ID20
1988 Renault 4 TL
2007 Porsche Turbo
