WANTED: Thermostat housing for my 91 J reg BX 19 TGD Meteor Diesel Automatic
This is the thermostat housing which is secured with 4 bolts, narrow hose angled at 45 degrees on top, narrow hose vertically mounted at the base, and large hose attached to the front of the housing.
Also has the tube into which fast idle cable is inserted on the left hand side in the photographs.
Has bleed screw near top of the housing. Note the small makeshift bleed screw in the photos!
Number written on casing:
SOFAB
9351065880
8-1
(91) 91 written in a circle; the year of manufacture
WANTED: BX 19 Diesel non turbo thermostat housing
Dyane425
Re: WANTED: BX 19 Diesel non turbo thermostat housing
I probably got one or two spare.
Dyane425
Dyane425
Dyane425
PM Sent with info on part numbers
[/quote]
