WANTED: 4 x FUEL INJECTOR SLEEVES BX 1.9 Diesel
Dyane425
Need the sleeves that fit into the fuel injector orifices.
Re: WANTED: 4 x FUEL INJECTOR SLEEVES BX 1.9 Diesel
'Sleeves' I thought they screwed straight into the cylinder head with copper washers to seal them?
Dyane425
- x 116
I am not sure what he means as well. Over to you Dyane.
barry badger
There are steel inserts that the injector nozzles seal against, i've never had the need to remove them. I've got a few spare cylinder heads i'll have a go tomorrow and see how easily they come out.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
sdelasal
Do you mean the steel washer like thing - fire seal I think it's called. For example - https://www.306oc.co.uk/forum/archive/i ... 15219.html
barry badger
i had a go at getting one of the inserts out but couldn't get it to move. what's wrong with yours? can you post a picture to make sure i'm definitely trying to remove the right parts and i'll have a more determined go.
BxTZDkyle
They are not really needed I have never fitted these in any xud engine Peugeot always try to sell them tho
barry badger
these are still listed as being available,
part no 1982 04
part no 1982 04
