Rpm drops and raises quickly
Janus
My Cars: 1988 BX 19 gti 8 valve
Post by Janus »
I have 1988 BX 19 gti and problem occurred today with rpm dropping when I press accelerator quickly/hard. Rpm raises around 2000 and then quickly drops to 1000-0 rpm after that it raises quickly back to 2000. Sometimes engine shuts off completely. Today I checked ignition and fuel pump. Both suth off completely during rpm drop. If I press accelerator lightly there is no problem. I also checked throttle position switch but it seems to be working.
This is my first BX and first petrol car so all advises are welcome :D
Janus
Re: Rpm drops and raises quickly
Post by Janus »
Oh I forgot to mention that engine fault light is on during the rpm drop.
Air flow meter?
Janus
Post by Janus »
I have to chekck that today. Can I read the fault codes from ECU without any special equipment? I think my BX has jetronic ECU.
Janus
Post by Janus »
Kitch wrote: Tue Nov 13, 2018 10:01 amAir flow meter?
Thanks for advice! I cleaned it and problem seems to be away now.
Glad to hear it!
Janus
Post by Janus »
Kitch wrote: Thu Nov 15, 2018 9:35 amGlad to hear it!
Unfortunately the problem came back. I did some testing yesterday and cleaned some connections and grounding point for ignition module. Biggest suspect is ignition module because I have heard those tend to break sooner or later. Ignition coil and coils lead are possibilities too.
It seems that voltage is fine in the primary side of the coil during rpm drop. Secondary side in the other hand is completely dead about half a second.
Janus
Post by Janus »
Quick update. I changed ignition module and ignition coil to new ones. didn´t change a thing. TDC sensor would be my next guess.
x 113
I seem to remember that when I had similar erratic symptoms 20 plus years ago I was able to check the flow meter's output, with engine not running, while moving the flap slowly and measuring the output voltage. I think I used both an oscilloscope as well as a voltage meter.
Does the rev counter drop to zero during the malfunction indicating a loss of ignition pulses ?
There is a way of reading the ECU fault codes. It is clunky and often inconclusive and involves looking at the error light flashing sequence.
Then when you have exhausted checking the ignition side what about fuel filter, dirty fuel, fuel pressure.
Janus
Post by Janus »
Jaba wrote: Fri Nov 16, 2018 6:39 pm I seem to remember that when I had similar erratic symptoms 20 plus years ago I was able to check the flow meter's output, with engine not running, while moving the flap slowly and measuring the output voltage. I think I used both an oscilloscope as well as a voltage meter.
I checked the ignition with stroboscope and during malfunction it is completely off. Rpm drops to zero (or near it) even when i am driving the car. So I think it can´t be fuel related problem or at least it is improbable. I have read that there is safety relay that cuts out fuel pump if engine rpm signal is lost. That would explain fuel pump turning off during fault. correct me if I´m wrong but what i can understand Jetronic ECU can´t affect ignition anyway. It only gets rpm signal from ignition module.
I have to do more testing tomorrow but unfortunately I can´t get any parts during weekend if needed. Even worse fact is that I need to get new isnpection done next friday :D Well I think this is part of the hobby. I bought this car about a month ago and as I said earlier this is my first BX. So there is still alot to learn. Thankfully this is not my first Citroen :D
x 113
I am not sure of the mechanism used but with this ECU system, when working normally, while slowing down with the throttle closed the fuel is cut off and maybe ignition too until the revs reach about 1500 when it starts burning fuel again. I used to be aware of this because I felt a very slight surge at 1500 revs which made me realise that this was what was happening.
Have you been able to get hold of the Bosch diagnostics for your jetronic system ?
Janus
Post by Janus »
Jaba wrote: Fri Nov 16, 2018 8:15 pm I am not sure of the mechanism used but with this ECU system, when working normally, while slowing down with the throttle closed the fuel is cut off and maybe ignition too until the revs reach about 1500 when it starts burning fuel again. I used to be aware of this because I felt a very slight surge at 1500 revs which made me realise that this was what was happening.
Maybe I need to dig deeper to that. Even though this problem occurs while I accelerate. Maybe throttle position switch could cause this after all. I have not been able to get bosch diagnostic tool. where can I find some article about reading the fault codes via engine fault light?
x 113
Janus wrote: Sat Nov 17, 2018 11:33 am Maybe I need to dig deeper to that. Even though this problem occurs while I accelerate. Maybe throttle position switch could cause this after all. I have not been able to get bosch diagnostic tool. where can I find some article about reading the fault codes via engine fault light?
I think I have the jetronic diags somewhere if you need them I can mount a search. They might be online here though: http://citroen.tramontana.co.hu/en/electrics
Janus
Post by Janus »
Jaba wrote: Thu Nov 22, 2018 12:44 pm
Thankls for the link. The problem have vanished again tough. I had ordered the TDC sensor before that so I might as well change it when it arrives. If this problem occurs again I have to shake wires in engine bay. It might be bad connection somewhere.
