Re: West Bay Valver
greendale65
x 20
Re: West Bay Valver
Post by greendale65 »
Hi all, had some new front spheres last week the correct ones
fitted don't seem as good as old ones more firmer
feel more road bumps any thoughts on this.
Thanks.
senmathal
My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
Re: Re: West Bay Valver
Post by senmathal »
Maybe your old ones was not the correct type. I think it´s common to put softer spheres from some other BX model on 16 Valve. Original 16 Valve is relatively firm compared with other BX
/Mats
greendale65
x 20
Hello mats i did think that would be the reason give it time i will
change them thanks for your reply
Alan
senmathal
Post by senmathal »
Is there any number marked och the spheres? If so it will be possible to identify them. There are three parameters that have impact to the spheres. The volume the damper bore and the pressure. A bigger sphere with higher volume give a softer sphere and it´s easy to sea the different between a 500 and 400 cc sphere. 16 Valve should original have the smaller 400 cc Sphere. Also a higher pressure and bigger bore fore the damper slot give a softer ride. The first thing you can do is to compere the outer size of the sphere if they are the same. The difference between the bore is maybe not so easy to compere depending of the small difference.
But the best is to look fore the marking on them. If you give as the marking here I think we can help you to identify them.
/Mats
greendale65
x 20
Hi,/mats thanks for info i did discover that the garage topped up air in the tyres
reckon that didn't help i will get some spheres 55 pressure roads are full of
holes ok on main roads'
Thanks for your info.
8) 8) 8)
