Good points:
- 1.6 petrol with only 75k (125km) ish
- Drives very well
- New oil, filters and LHM fluid this month
- New front tyres
- New starter motor
- New handbrake/brake lines/driveshafts
- Suspension works perfectly
- No rot ANYWHERE
- Tow bar
- Boot struts actually work
Bad points:
- Passenger side window motor disconnected as window was stuck down
- Radio is temperamental
- It has a carb from the 1.9 (I believe) so is overfuelling a little. it still runs well and gets around 30mpg and so I've left it as is
- it's not UK registered, but NOVA is in place
I had all the above work carried out (and more) in preparation for it's MOT but life keeps getting in the way and I'll probably never get around to it so it's sold as is. All the french paperwork is present and several French invoices (I can translate if necessary). Any inspection is more than welcome. Postcode is BA5 3ER and delivery is potentially available depending on location. I'm after £800 and not interested in any offers.
Thanks.
1989 Citroen BX16 Estate 1.6 LHD (Image)
- My Cars: 2010 Audi A6 2.0 TDI CR170
2008 Dodge Avenger
1988 Citroen BX 1.8 DTR Estate
- x 28
Re: 1989 Citroen BX16 Estate 1.6 LHD (Image)
Looks nice and sorry if this is pissing on your parade but if it is overfuelling could it ever pass an emissions test at idle?
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
2008 Dodge Avenger
As far as I’m aware it’s JUST within the parameters. I plan on MOTing and registering it later this month prior to listing on eBay so we’ll see
- x 28
Cool, with that confirmed it looks like a good buy. Good luck!
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
