Wanted Part Wiring Loom
cms
Post by cms »
I need the wiring that goes from fuse box under dash passenger side. Up the door piller and feeds the interior light/sunroof ect.
1986 Hurricane. If possible the sunroof motor and related relays. Had a little fire in the door pillar not too serious just melted the wires. Can anyone help? I am assuming that the loom is pretty much the same in all models other than the sunroof feed.
x 82
Re: Wanted Part Wiring Loom
Could you make one if I send basic dimensions/wiring circuit?
x 83
You have had a lucky escape to get no fire damage as well. Usually this is due to water getting past the aerial and shorting out electrics in the sunroof central locking area.
Sorry I don't have that part of the loom. There are one or two people breaking at the moment.
x 137
I have a complete interior wiring loom from a turbo diesel 1990 model it had a sunroof fitted
I should imagine it will have the loom you need on it somewhere, if you want it it's £30 for the whole shabang and you can butcher it at Yr own free will, all the plugs and connectors are intact.
cms
Post by cms »
Yes rutter123 that would be perfect. Ive been away so this is the first chance i have had to get back to you.
cms
Post by cms »
Have sent you PM.
cms
Post by cms »
Which part of the county are you in? maybe I could collect?
x 137
Pm replied
