Bx engine swap
Bx(1,4)
My Cars: Bx 1,4
Bx engine swap
Post by Bx(1,4) »
Hi, I have the 1992 bx 1,4 and i would like to swap my engine. I am thinking of installing an C5 engine but i do not know if it can fit. Also I dont know if I can put the c5 ecu if the engine fits.
x 138
Re: Bx engine swap
It depends on how much money you want to throw at it and your technical ability, anything is possible. You need to consider the drive train, subframe, changing the hydraulic system to name but a few and the extra weight of a c5 lump.
An Eastern European guy fitted a 3.0 v6 Xantia engine into a bx but not without a lot of adjustments.
Kaapelimies
x 16
Re: Bx engine swap
Post by Kaapelimies »
C5 is a problem because of CAN-bus electrics. You really have to know what to do if you think of it..
Bx(1,4)
My Cars: Bx 1,4
Re: Bx engine swap
Post by Bx(1,4) »
So, If I want to swap to a c5 engine I need to change the hydraulic system? What about an other engine (for example xsara mk2 engine)?
Bx(1,4)
My Cars: Bx 1,4
Re: Bx engine swap
Post by Bx(1,4) »
Also if I decide to put a c5 engine I will connect to ecu only the wires for the engine without having other problem?
Kaapelimies
x 16
Re: Bx engine swap
No and no. Search for a donor car without CAN and antitheft, otherwise it will be two years of studying. Hydraulics is no problem, physically the engine will fit but nothing will work. Have a google on CAN and antitheft. Even if you can find a description of C5 electrics will help you make the decision to not do it..
Bx(1,4)
My Cars: Bx 1,4
Re: Bx engine swap
Post by Bx(1,4) »
So, what car would you suggest me?
Kaapelimies
x 16
Re: Bx engine swap
Why do you want to change the engine? Any donor BX would be an easy place to start with.
xantia_v6
My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12
x 72
Re: Bx engine swap
Post by xantia_v6 »
Generally speaking, any PSA engine (up to 2.1 litres) from the 1990s should fit, See https://en.wikipedia.org/wiki/List_of_PSA_engines for a shopping list... You are probably more interested in something from the XU or XUD (or perhaps EW/DW) ranges.
The higher power engines (2.0 TCT, 2.1 TD and 2.0 HDI 110) use the larger ML5 gearbox which may be difficult to fit in a BX.
Bx(1,4)
My Cars: Bx 1,4
Re: Bx engine swap
Post by Bx(1,4) »
Kaapelimies wrote: Thu May 14, 2020 9:53 pm Why do you want to change the engine? Any donor BX would be an easy place to start with.
Because it has more than 350.000 km and I said that if I change it why not to put a newer one.
But if I decide not to do it I will make a full repair/ restoration
Re: Bx engine swap
The 1.4 engine is shared with lots of other Peugeot Citroen cars so maybe look for a lower mileage one of those? Or maybe a 1.6 Version of it
My Cars: 1985 Citroen BX19 GT
2013 Nissan Leaf Acenta 24Kw
x 199
Re: Bx engine swap
Post by saintjamesy89 »
Ooh, interesting project! I liked my 14 TU and can imagine a bigger TU variant could only be more fun.
