My BX14 RE- Sold.
Kaapelimies
- x 16
Re: My BX14 RE- NOW WITH LEAKS!
Well that's only what makes Citroen so special and famous for: The hydroleak system.
white exec
Built-in rustproofing . . . and not a moment too soon, by the looks of that strut!
Fumbler
- My Cars: Citroen BX14 RE
Nissan Micra Shape - x 31
It's worse than it actually is! I'm going to slow the corrosion sitution down a bunch when I have a weekend to just do work.white exec wrote: Tue Aug 24, 2021 5:46 pm Built-in rustproofing . . . and not a moment too soon, by the looks of that strut!![]()
Fumbler
Fumbler wrote: Tue Aug 24, 2021 6:10 pmIt's worse in the picture than it actually is! I'm going to slow the corrosion sitution down a bunch when I have a weekend to just do work.white exec wrote: Tue Aug 24, 2021 5:46 pm Built-in rustproofing . . . and not a moment too soon, by the looks of that strut!![]()
- x 113
Here is what I did recently for a few quid with parts from a local hydraulics company using diesel leak back tubing which is about 3.5 to 4mm id.
Saves all the faffing with that clip.
Fumbler
Indeed, this is what I've done for now. I'll replace the entire hose on Friday hopefully. The vent pipe was too far gone to patch up.Jaba wrote: Tue Aug 24, 2021 6:14 pmHere is what I did recently for a few quid with parts from a local hydraulics company using diesel leak back tubing which is about 3.5 to 4mm id.
Only fit Genuine Citroen or Chevronics supplied strut return pipes as pattern ones can be troublesome. It's worth paying the extra.
jamescarruthers
- x 36
What about EuroCarCare ones? It’s the same part on the C5 and now I’m worried!rutter123 wrote: Tue Aug 24, 2021 7:55 pm Only fit Genuine Citroen or Chevronics supplied strut return pipes as pattern ones can be troublesome. It's worth paying the extra.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
Speaking from experience with pattern strut returns-its your choice.
jamescarruthers
- x 36
Oh well, will cross fingers but take your advice on Citroen/Chevronics if they do fail early. Cheers.rutter123 wrote: Wed Aug 25, 2021 9:08 am Speaking from experience with pattern strut returns-its your choice.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
Fumbler
Re: My BX14 RE- Less Leaky
OK, I've done a few things over the past couple of days. They have been:
- Had the tracking done. Car steers the best it's ever done and the wheel is centred (Yay!)
- Replaced a boot strut with a spare I had. I need to replace the other but at least I can open the boot with some ease
- Re-bodged my return pipe bodge with longer sections of brake pipe and jubilee clips. It's actually working
- Washed the thing for the first time in a month or two. I forgot how shiny it actually is
- Bought ignition coil
- Bought cavity wax to top-up the areas previous people have done it. This car was actually taken care of once upon a time
- Bought more chainsaw bar and chain oil to undercoat the car once I've painted the boot floor.
- Fit new starter motor
- Paint wheels and refit trims
Fumbler
While it's working well, going over every little tiny undulation on the road now makes a wonderfully horrible grinding feel at the front which I can feel through the floor, accompanied by an audible groan. This only happens at 30MPH and below, but I sense trouble afoot. What could be the issue? Suspension arm bush? Worn strut?
Kaapelimies
- x 16
Is there a difference between gears selected? Same feeling when clutch pressed down? Motor braking, accelerating, rolling neutral?
Fumbler
Same effect when rolling in neutral, having the clutch in, engine braking and being in gear. Only happens after a strong series of bumps and at/below 30MPH though. Without the noise of the engine accelerating you can hear the noise a lot better. It seems to be coming from somewhere in the front driver's side. I have a feeling my struts are worn because they stick when settling and rising up. I have a spare strut and mount/gaiter assembly. Good that I have them, really because the ones currently on the car inspire not much confidence.Kaapelimies wrote: Wed Sep 01, 2021 8:59 pm Is there a difference between gears selected? Same feeling when clutch pressed down? Motor braking, accelerating, rolling neutral?
That sounds like a wheel bearing and the grinding could be your brake disc rubbing on something it shouldn't.
