Wanted: BX 16 TGS headrest (rear)
Routemaster
My Cars: BX 16 TGS
Post by Routemaster »
Does anyone have a rear headrest (or ideally two) looking for a new home?
Any leads gratefully appreciated.
x 148
Re: Wanted: BX 16 TGS headrest (rear)
If you could take a picture of the fabric that would help
You can cut down front ones to fit.
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 70
Post by white exec »
Front headrests will also fit the rear. You just need to trim 55mm off the bottom end of the steel column and its plastic surround, and refit the plastic end closer. Nice easy job.
Routemaster
My Cars: BX 16 TGS
Didn't realise the fronts can be made to fit too, thank you.
I only have the attached photo to hand but it's a grey cloth interior.
I'm open to any colour as that's secondary to the safety of passengers in the rear seat.
x 148
Ah yes this is "grey tweed" and fairly common so you should be able to find some hopefully
Routemaster
My Cars: BX 16 TGS
Appreciate the colour identification, many thanks...I'll scout around.
white exec
x 70
Found mine on Ebay - a listing by someone in Kent.
Try googling something like 'Citroen BX headrest grey', hitting Images, and see what the link is under each one.
Ads with pictures usually end up showing under an Images search.
Try also garage80.nl. Lots of BX parts there.
panky
'88 BX GTi (a long time ago)
x 84
Post by panky »
white exec
x 70
Not sure they're an exact match for the grey tweed. The covers on them look a tad thin and baggy! :?
SFAIR, headrests are normally finished in exactly the same material as the seats.
Routemaster
My Cars: BX 16 TGS
Garage80 looks a good tip, thank you.
I'm wondering if the pair shown have covers as the baggy appearance doesn't look very 'OEM'.
white exec
x 70
Wondered about that too - a BX antimacassar, maybe?
Ask them what's underneath...
