My BX14 RE- Sold.
Fumbler
- My Cars: Citroen BX14 RE
Nissan Micra Shape - x 31
Fumbler
Re: My BX14 RE
Performed more Citrobics.
The car now sits at the correct height.
Status: confuzzled.
Status: confuzzled.
- x 116
Re: My BX14 RE
Your dizzy oil leak is probably cos a new o-ring is needed.
Fumbler
Re: My BX14 RE
Probably. That side of the engine in general is rather oily so I can imagine there may be other leaks somewhere.
Fumbler
Re: My BX14 RE
Bought a very clean Peugeot 205 XS intake with a view to perhaps, one day, fit it to the BX. Now all I need to do is find a Solex 32/34.
white exec
Fumbler
Re: My BX14 RE
Good shout. They have one from a suitcase-engined BX14 that would definitely work, but I don't have €200.00 to spare. I'll keep periodically checking their website as I'm fairly sure they'll pick up another at some point.white exec wrote: Mon Sep 20, 2021 8:01 pm Try garage80.nl, who break a good few BX and other Citroens.
white exec
Re: My BX14 RE
They are not cheap, but do have some very tidy, clean parts, decently photographed for the site.
I got my late-type black non-sports steering wheel from them for €40.
Fumbler
Re: My BX14 RE
https://www.ebay.co.uk/itm/115014000720 ... Track=true
This would work but would need re-jetting. It's a good job I have two carburettors for the engine I could rob the jets off of. However, I am told and have read that the auto chokes are rather bad, dreadful even. The only guide I've found for conversion to manual is very broken. How difficult would it be?
Even if I bought a Solex/Weber 32/34 for a Peugeot 205 XS (same engine as the BX), I'd still have to contend with the autochoke. What's the solution?
Kaapelimies
- x 16
Re: My BX14 RE
Correct me if I'm wrong, but I remember that Solex and Weber have different bolt pattern, so they don't fit the same intake manifold? And the jets also don't mix, they are very different on the inside.
Fumbler
Re: My BX14 RE
Solex and Weber merged in 1989, and this particular carburettor in the link is a Solex 32/34 with different branding. Even the label on the box states it's a direct replacement for one.Kaapelimies wrote: Tue Sep 28, 2021 5:27 pm Correct me if I'm wrong, but I remember that Solex and Weber have different bolt pattern, so they don't fit the same intake manifold? And the jets also don't mix, they are very different on the inside.
xantia_v6
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 72
Re: My BX14 RE
Solex and Weber carburettors generally always used the same design of jets, even back to the 1960s, maybe there was a licencing agreement? In most cases Solex had an almost identical carburettor available for every design of Weber.
Kaapelimies
- x 16
Re: My BX14 RE
Those I've seen in Citroens were not compatible, starting from GS. From -89 and newer I have no idea, we got all injected in -90. But good to know there may be a spare available as Weber, but not sure if they're like Solex so not maybe better after all.. And "Almost similar" is exactly what I found, bolt pattern was 2mm off.. (:
Fumbler
Re: My BX14 RE
Rest assured the bolt patterns on the ones I'm looking at are the same. They're labelled as replacements for their Solex counterparts and visually look identical.Kaapelimies wrote: Wed Sep 29, 2021 2:59 pm Those I've seen in Citroens were not compatible, starting from GS. From -89 and newer I have no idea, we got all injected in -90. But good to know there may be a spare available as Weber, but not sure if they're like Solex so not maybe better after all.. And "Almost similar" is exactly what I found, bolt pattern was 2mm off.. (:
However, jet-wise, they aren't! There are several different jet configurations for the BX16 between certain model years, who made the carburttor and, perhaps more obviously, transmission type. As the suitcase-engined BX14 had a Solex 32/34 I'm going to try and at least get as close to the parameters those used. If bolt patterns are the same, I might try to get a 34/34 and combine the jets I have in both the carburettors I currently own.
Anyhow, this little tangent will get pretty expensive so I'll likely be waiting for a good while before any of this becomes reality.
- x 94
Re: My BX14 RE
No you wouldn't, they're manual choke. Same as an AX GT.Fumbler wrote: Tue Sep 28, 2021 3:45 pm
