I’ve haven’t an opportunity to go over the car with a fine tooth comb yet to establish exactly what needs doing and to formulate a plan of action, but the first thing I’d like to address is the leaking O/S rear brake pipe as it’s making a right mess on my garage floor.
Yesterday I jacked the car up to take a closer look and found LHM dripping from the metal brake line about 2 inches before it goes into the calliper.
It appears I can get a replacement easily enough but I have a few questions:
- Is it possible to replace the rear brake lines without having to drop the subframe slightly so the pipes can be carefully threaded where they need to go.
- When I disconnect the brake line from the splitter valve, am I going to get drowned in LHM? I assume the system is constantly under pressure judging by the pool of fluid on my garage floor. Perhaps it’s just because I had the suspension on high the last time I fired it up?
- Where should I buy the LHM brake line seals from - I think I need 3.5mm
- Obviously I’ll also need new calliper bleed nipples. Any idea what size I need to look for and where to source these from? I found this info on another post but not sure it applies to the 16v (fronts: m7 x 1) (rears m8 x 1.25)
