Window crank removal
Jugostran
My Cars: 1989 Cimos-Citroën BX 16 TRS
2007 BMW 318D (the "company car")
x 44
Post by Jugostran »
Hello everyone!
So this is an unusual post for me, as I'm asking for a friend. His BX is a 1984 BX 14. The problem we're having is that he can't get the window crank off (which he needs to do in order to remove the door cards). Just pulling it off doesn't seem to be working. Is there a trick to getting it off?
Many thanks!
Proudly daily driving a 1989 BX 16 TRS since 2021
thorter
Re: Window crank removal
Post by thorter »
Push the door card in, and also the contacting plastic ring. This should reveal a pin through the spindle. Push it out and don`t loose it, then handle will com off.
Jugostran
x 44
Post by Jugostran »
thorter wrote: Fri Sep 29, 2023 9:32 am Push the door card in, and also the contacting plastic ring. This should reveal a pin through the spindle. Push it out and don`t loose it, then handle will com off.
That worked, thank you!
