Repairing suspension pipes
Kieron g
My Cars: 2001 Citroën berlingo multispace 1.9d
2000 Citroën berlingo multispace 1.8i
1988 Citroen BX 1.6 RS (sun seeker)
Post by Kieron g »
Could someone advise if it is considered good or acceptable practice to replace a section of a suspension pipe please.
I notice there is a kit specifically for this purpose for sale on the Internet.
I have a pin hole or small split in the pipe from the height corrector to the o/s/f suspension unit as pipe runs along what looks like a front cross member near the height corrector itself.
It is quite well tucked away and seems an unusual place to corrode, the rest of the pipe looks ok.
Thanks
David
x 47
Re: Repairing suspension pipes
Post by David »
Personally, I’d recommend replacing the whole pipe that’s burst, as if it’s corroded in one place, then it could’ve gone somewhere else too.
Also, the Citroen hydraulic lines are a different size & have different fittings/ ends on them than standard brake pipes. If you’ve found a common brake pipe join & flaring tool, then it won’t work on the Citroen pipes.
All that being said, however, if the rest of the pipe looks alright & you get the correct unions, connectors, seals & Citroen flaring tool, then there’s no reason why you can’t just put a join in it, the same way as on a standard brake pipe, but, as mentioned above, I wouldn’t recommend it.
Hope that helps.
Kieron g
Post by Kieron g »
Thanks for reply. I'll take the full pipe off and see about getting another made up.
x 159
Ive just had my front to rear pipes replaced on my MK1 with Kunifer, you fit and forget,
