BX Project
x 103
Re: BX Project
Citroën BX – XPO – Fuel Pipes – Eps37b
Before the engine went back in, this seemed like the right time to replace fuel pipes and recommission the fuel system.
https://bxproject.co.uk/blog/citroen-bx ... es-eps37b/
x 103
Re: BX Project
Citroën BX – XPO – Finishing the Engine – Eps38
While recent XPO progress has been slow, finishing the engine ready to go back into the engine bay has been a big emotional boost.
https://bxproject.co.uk/blog/citroen-bx ... ine-eps38/
x 103
Re: BX Project
Citroën BX – XPO – 16V Gearbox – Eps39
Only a few years after starting, the 16v gearbox was overhauled and bolted back onto the engine, ready for installation.
https://bxproject.co.uk/blog/citroen-bx ... box-eps39/
x 103
Re: BX Project
Citroën BX – XPO – Welding Repairs – Eps40
In a slight segway from getting the engine running in XPO, this article looks at some of the smaller welding repairs that have been completed.
#BXproject #citroen #citroenbx #carrestoration
https://bxproject.co.uk/blog/citroen-bx ... irs-eps40/
x 103
Re: BX Project
Citroën BX – XPO – Engine Installation – Eps41
Almost a year ago today, the engine installation on XPO was completed. In this article, we take a look at how the installation was achieved.
https://bxproject.co.uk/blog/citroen-bx ... ion-eps41/
x 103
Re: BX Project
Citroën BX – XPO – Hydraulics – Eps42
Flying through the updates now in the hopes of getting ahead of the huge press coverage when news gets out that XPO is on the road and in shakedown.
This time, hydraulics. With a look at strut leak-back hose alternatives.
https://bxproject.co.uk/blog/citroen-bx ... ics-eps42/
x 103
Re: BX Project
Citroën BX – XPO – Becoming Driveable – Eps43
At the start of 2024, the pace was picking up, and XPO was becoming driveable. Just a cooling system and drive shafts to go. Or was it?
https://bxproject.co.uk/blog/citroen-bx ... ble-eps43/
x 103
Re: BX Project
Citroën BX – XPO – Exhaust Installation – Eps44
Engine running, and rather than continue deafening myself with the raw tones of the XU9j4, exhaust installation is the order of the day!
https://bxproject.co.uk/blog/citroen-bx ... ion-eps44/
x 103
Re: BX Project
Citroën BX – XPO – Steering Rack Leak– Eps45
With the engine running and exhaust installed, the hydraulic leaks were starting to spring up. The worst was the steering rack leak!
https://bxproject.co.uk/blog/citroen-bx ... eak-eps45/
x 103
Re: BX Project
Citroën BX – XPO – Hydraulic Octopus – Eps46
While the steering rack change didn't stop the hydraulic leaks, a new hydraulic octopus (leak back harness) should stop the fluid loss.
https://bxproject.co.uk/blog/citroen-bx ... pus-eps46/
x 103
Re: BX Project
Citroën BX – XPO – Wheel Alignment – Eps47
With the steering rack changed and hydraulic leaks resolved, I finally had usable forward motion.
But bad wheel alignment was stopping reversing movement and the wrong clutch cable stopping meaningful clutch control!
https://bxproject.co.uk/blog/citroen-bx ... ent-eps47/
x 103
Re: BX Project
Citroën BX – XPO – Bodywork Revival – Eps48
After a short sabbatical, I'm back with the latest XPO instalment. We're clearly in the finishing strokes on XPO with only two articles left after this one. This time, I'll be looking at the body work revival miracle!
https://bxproject.co.uk/blog/citroen-bx ... val-eps48/
panky
'88 BX GTi (a long time ago)
x 170
Re: BX Project
Post by panky »
Superb job, I love.
x 103
Re: BX Project
Citroën BX – XPO – The Finishing Line – Eps49
Nearly four years into the XPO project, the finishing line is in sight. The BX is almost ready for MOT until a last-minute disaster strikes!
https://bxproject.co.uk/blog/citroen-bx ... ine-eps49/
x 103
Re: BX Project
Citroën BX – XPO – Pastures New – Eps50
After nearly four years, XPO is off to pastures new. But not before a lap around a motor racing circuit and a near 'thermal event'.
https://bxproject.co.uk/blog/citroen-bx ... new-eps50/
