Imgur is Kaput
xantia_v6
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 72
Re: Imgur is Kaput
There is a work-around... If the images are placed in the body of one post, then next time I rum the scripts, they will be picked up and they will then work in the signature.
Jugostran
- My Cars: 1989 Cimos-Citroën BX 16 TRS
2007 BMW 318d (the "company car") - x 51
Re: Imgur is Kaput
Noticed my name come up. The signature pics show fine on my end, so I assume the fix worked (thanks!)
panky
'88 BX GTi (a long time ago) - x 174
Re: Imgur is Kaput
That will be because you're in a country unaffected by Imgur's decision. It's all because of the UK's online safety act and Imgur deciding it was easier to deny UK users access than to comply with UK legislation.
Jugostran
Re: Imgur is Kaput
Oh. This is about that, huh. Damn, very unfortunate for you lot. I guess I'm going to start a mass mailing list to send you BX pictures from now on.panky wrote: Mon Oct 20, 2025 10:43 pm That will be because you're in a country unaffected by Imgur's decision. It's all because of the UK's online safety act and Imgur deciding it was easier to deny UK users access than to comply with UK legislation.
- x 116
Re: Imgur is Kaput
I can see the pics when I connect via a VPN server in France which is what I would expect.
It is not clear (to me) if it is just signature pics that are blocked or is it those in the text too, because I am sure I remember seeing posts with several blocked image placeholders.
panky
Re: Imgur is Kaput
It's still just the signatures and if any others are missing then the monthly back ups should bring them back thanks to Mike.xantia_v6 wrote: Sat Oct 04, 2025 10:51 am By the magic of software, all imagur image links posted to this forum (before today) should now be working again for UK users.
Any imagur image links posted after today will not work until I do another manual image backup run (which maybe once a month, or may be a lot less frequent).
Note that image links in signatures are not currently handled by my scripts.
