DKK
panky
'88 BX GTi (a long time ago)
x 170
Re: DKK
Post by panky »
That's the tape that's jammed in the old player. I might need to resort to violence :twisted:
panky
x 170
Re: DKK
Post by panky »
Started him up again this morning and all was fine, except the exhaust sounded a bit fruity
Can't see anything wrong here :shock:
That'll be it then :? The exhaust has left the building
I guess the big backfire did a number on my perfectly good back box :|
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 78
Re: DKK
Post by Dave_16v »
If it did that, you could say you were lucky that's all it did. 😱
panky
x 170
Re: DKK
Post by panky »
At least the exhaust isn't as restrictive now :D
RobC
My Cars: 1991 Citroen BX 16v
x 30
Re: DKK
Post by RobC »
Crikey!
panky
x 170
Re: DKK
Post by panky »
And all because I wanted to Gummi Pfledge me door rubbers :shock:
panky
x 170
Re: DKK
Post by panky »
New back box fitted and normality returns.
Here's a conundrum The drivers footwell got wet a while ago so the soggy mess of old soundproofing was pulled out, the carpet dried, new insulation fitted and everything put back together. Since then he's been under a waterproof cover which keeps the outside bone dry but.........the footwell was soaked again. It's not coolant as the system is filled with Evans waterless, it's not washer fluid as I've has the bottle out and checked underneath it looked fine but put extra sealer on the seams just in case. So where is the water coming from? My investigations continue.
panky
x 170
Re: DKK
Post by panky »
Problems problems problems.
Same issue as I had before I fitted a new drive shaft to the nearside. Juddering on take off that feels like going over anti skid surface that can be felt through the steering wheel but eases off at speed. Before I spend any more on a new offside drive shaft (the long one) how much play should there be in the joints? There is very little twisting play but the outer shaft can be moved easily, by hand, lengthwise between the joint by about half and inch, the new shaft has zero play as far as I can tell.
Shall I go for another drive shaft or look elsewhere for a fault?
panky
x 170
Re: DKK
Post by panky »
Help please. Is there a resource where I can trace the original part No for the offside drive shaft. I've done a Google search which came up with these alternatives but I'd like to find out for sure before ordering as there are various versions out there with different spline counts.
Thanks
John
From a Google search I find the following
95606797
95619480
96009410
32736G
jamescarruthers
x 37
Re: DKK
Post by jamescarruthers »
I don't know but https://www.driveshaftuk.com/ sorted me out for my C6.
Original parts numbers can be looked up on Frenchcarforum.co.uk, paying the £10 minimum donation https://frenchcarforum.co.uk/forum/view ... 54#p638654 It is unfortunately nigh-on impossible to search on there because it ignores two-character parts of the search, like "BX"!
Do these help from here http://www.ckc.dk/cgi/catlist?:
http://www.ckc.dk/cgi/vcat??MIC01230A
http://www.ckc.dk/pubs/BX-82.pdf
http://www.ckc.dk/pubs/MAN058881.pdf (section 5 is driveshafts)
http://www.ckc.dk/pubs/MAN058882.pdf (part 2 of above just for completeness)
I note some dire warning about pulling driveshafts out on pre-1987 cars in that you have to support the internal planet gears.
Last edited by jamescarruthers on Thu Mar 12, 2026 11:58 am, edited 3 times in total.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
panky
x 170
Re: DKK
Post by panky »
Many thanks for that.
I read in the manual that you need to fit a tube of the correct diameter if both drive shafts are removed, I've alredy done the near side so hopefully all will be well.
panky
x 170
Re: DKK
Post by panky »
I've registered and contributed but can't find the link to the parts list so I've left a query in the hope someone will give me directions.
Once again many thanks for your help
jamescarruthers
x 37
Re: DKK
panky wrote: Thu Mar 12, 2026 1:02 pm I've registered and contributed but can't find the link to the parts list so I've left a query in the hope someone will give me directions.
Once again many thanks for you help
Ah no, there is no parts list to access. You tell the guys what you want and they access the Citroen parts site and get back to you with screenshots, etc. This used to be free but Stelantis put a stop to that.
In fact, I think this site and FCF are hosted by the same people.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
jamescarruthers
x 37
Re: DKK
You need to post in this part of the forum https://frenchcarforum.co.uk/forum/view ... hp?t=69962
Or, from the front page click "Citroen", then in the top "Announcements" posts you will see the thread entitled "Citroen, DS Automobiles and Peugeot Official Part Number Requests"
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
jamescarruthers
x 37
Re: DKK
Oh no, I'm sorry but this service is temporarily suspended https://frenchcarforum.co.uk/forum/view ... 10#p834010
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
