Great to find an English-speaking BX forum after months grappling with French mechanics vocab. on the bxworld list
I live in France and have been driving a 1990 BX Image 1.6 (aka Maud) since the start of the year. After being driven around the snowy Alps all winter with no complaints whatsoever, things are starting to go a little bit pear-shaped hydraulics-wise and I wanted to see if any of you had any thoughts.
So, the problems:
- the "conjoncteur/disjoncteur" (is it a pressure regulator in English?) ticks about every 6 seconds, so I'd guess the accumulator is due for replacement
- LHM leaking dripping off the large metal structure just in from the right-hand front wheel. Not a lot of fluid, just enough to make a little stain on the tarmac.
- this afternoon, at the end of a longish drive on a hot day, the STOP light and temperature warning came on at the same time. I pulled over to have a quick look and there didn't appear to be anything amiss, and she got me the last five minutes home with brakes and suspension as normal.
-also, the car sinks pretty quickly - back end within 15 mins or so.
What I'm wondering is whether these problems are linked or if it's just sod's law that a whole lot of separate things are happening at once. Particularly r.e. the stop light, do you think it could be an electrical rather than hydraulic issue?
Thanks a lot for any suggestions - it'd be great to know at least vaguely what's wrong to avoid the garage fleecing me too badly!
